entrecour Posted August 27, 2012 Posted August 27, 2012 Fisrt of all, sorry this will NOT be a complete report as I didn't have time to get the support files (family presure to get the TV working again!).. I just installed RS 1.2 in a working system based on RS 1.1. Unfortunately there was no tuned picture and autodiscovery did not show the local Unicast device. The RS test button indicated that RS was connected but still no tuned channel. I then reinstalled RS 1.1 and everything works ok again. I will try and test again later.
Tjod Posted August 27, 2012 Posted August 27, 2012 1.20 Not 1.2 RS 1.2 (16.6.2007) http://www.DVBViewer.tv/forum/topic/18273-recordingservice-beta/page__view__findpost__p__144766 RS 1.20 http://www.DVBViewer.tv/forum/topic/19629-recordingservice-beta/page__view__findpost__p__372090 make sure the DVBServer is enabled in the RS http://en.DVBViewer.tv/wiki/Options_Service_-_DVBServer
entrecour Posted August 27, 2012 Author Posted August 27, 2012 (edited) Yes my mistake, thanks for correcting that, it was RS 1.20 and RS 1.10 that I was referring to. I just checked the RS 1.10 config and DVBServer is enabled, so I assume it was in RS 1.20 also but I am not 100% certain. WHat I can say is that I didn't change that setting. Edited August 27, 2012 by entrecour
Tjod Posted August 27, 2012 Posted August 27, 2012 The default of "Enable Server DVBServer" has changed from on to off. Because future versions of the DVBViewer will change from Unicast to RTSP. And if you never changed the setting there is no entry for that in the service.xml and the RS use the default setting.
entrecour Posted August 27, 2012 Author Posted August 27, 2012 Thanks - I just reinstalled RS 1.20 and enabled DVBServer (it was disabled). That fixed it - all working ok now. How can I use / test RTSP (before the new DVBViewer is released)? I am very interested to get it running on an iPad / iPhone. Thanks!
Tjod Posted August 27, 2012 Posted August 27, 2012 You can download a channel list as m3u Play list (RTSP) in the web interface > Streaming > Direct connection http://IP:Port/stream.html?aktion=rtspchannellist_m3u And open it with a Player e.g. VLC
Lars_MQ Posted August 27, 2012 Posted August 27, 2012 I am very interested to get it running on an iPad / iPhone. Satellite FTA will work with the SAT>IP EyeTV application (for multi CPU apple devices and WLAN), I think it's 0.79 € in the app store. For using the direct RTSP stream with other players I don't know it's only tested with vlc and the DVBViewer. Feel free to test and please report back. Oh and be aware: RTSP is NOT transcoded. It's unchanged like the UPnP Streaming but in another container/transmission format.
Lars_MQ Posted August 27, 2012 Posted August 27, 2012 One thing, to avoid missunderstandings: The current DVBViewer can't handle RTSP or the RTSP playlist. The upcoming DVBViewer has a new virtual network device which will interface to the SAT>IP RTSP stuff automatically, like a easier to configure and use unicast device
bladel Posted August 28, 2012 Posted August 28, 2012 Elgato sat>ip App recognizes "DVB MediaServer", but doesn't list any channels. App offers to do a channel serach, but that fails too.
entrecour Posted August 28, 2012 Author Posted August 28, 2012 (edited) I haven't tried on an iPad yet, but I tried briefly on a PC using MPC-HC - I was not able to play the RTSP stream / playlist. I also tried using Quicktime but with no luck. I thought that both MPC-HC and Quicktime should be able to play RTSP streams. MPC-HC is able to play the direct stream (and you can use a different renderer if you want). Edited August 28, 2012 by entrecour
LocalHolgi Posted August 28, 2012 Posted August 28, 2012 Use VLC for this instead, i honestly never ever tried MPC since it uses Directshow - even if it comes with its own filters it might get screwed up with the installed one. VLC runs nicely with its own FFMpeg Library and you can be sure that it behave on each machine quite equal. You should also check your firewall.
entrecour Posted August 28, 2012 Author Posted August 28, 2012 LocalHolgi, Thanks for the tips. I want to hold off on installing VLC for the moment - I try to keep computers as clean as possible and I already have MPC installed. I don't think the firewall is the issue as 1) I can view the direct stream through MPC,and 2) it's all running on the same local machine. This is an extract for just one channel from the RTSP .m3u playlist that is created by DVBViewer web interface.... #EXTINF:-1,Telenor - BBC Entertainment rtsp://127.0.0.1:554/?src=1&freq=11325&msys=dvbs&plts=off&fec=78&pol=h&ro=0.35&sr=24500&mtype=qpsk&tnr=1,11325,24500,9750,0,0,6,5,640,512,256,1103,1,0,25,0,25,70&pids=0,18,256,512,576,640, I also tried the url by itself in mpc / open file and using the full ip address 192.168.0.x but neither of these attempts worked. I get "Failed to render the file." Obviously this could be a problem with MPC-HC rather than anything else, so I may end up installing VLC anyway!
entrecour Posted August 28, 2012 Author Posted August 28, 2012 I haven't tried this yet, but apparently OPlayer supports RTSP streaming on a number of platforms including iPhone ★ Supported File Format Extension ✔ XVID/DIVX AVI, WMV, RMVB, ASF, H264, MKV, TS, M2TS... most of all movie file formats. ✔ MP3, WMA, WAV, OGG, FLAC... most of all audio file formats. ✔ SMI, ---------------, SUB, SRT, TXT... most of all subtitle file formats. ★ Extra Features ✔ USB Sync: Use itunes to fast sync movies to your iPad. ✔ WIFI Upload: Upload movies by the web browser of your computer, support ie/safari/firefox/chrome. ✔ FTP Server: Upload movies by the ftp client of your computer, support cyberduck/filezilla. ✔ FTP Client: You can download files from FTP server to your iPad. ✔ SAMBA Client: You can download files from SAMBA server to your iPad. ✔ Dropbox support. ✔ Streaming: Support HTTP/RTSP/MMS/FTP/SAMBA streaming. http://itunes.apple.com/us/app/oplayerhd-lite-best-free-video/id385896088?mt=8 http://www.edavs.com/forum/
entrecour Posted August 28, 2012 Author Posted August 28, 2012 Some info on Sat>IP that I found, looks interesting... http://en.wikipedia.org/wiki/Sat-IP http://www.ses.com/satip http://www.ses.com/11193301/SATIP-White-Paper.pdf
entrecour Posted August 31, 2012 Author Posted August 31, 2012 Here are a couple of interesting RTSP articles http://www.streamingmedia.com/Articles/ReadArticle.aspx?ArticleID=80960 http://www.remlab.net/op/vod.shtml
