Porris Posted August 28, 2012 Posted August 28, 2012 (edited) Hello I have had DVBViewer with Anysee e30 Combo Plus, and it's basically crap. I an looking for an upgrade to the hardware, but I am wondering which card to go for. The main problem with the Anysee is, that DVBViewer does not support Anysee in terms of pay channels. So I am looking for: - DVB-C (probably C+T) card (internal card preferred, but USB thingy is also possible) - Possibility to change CI to Conax, since I live in Finland, or a option to buy Conax reader to the card - Reasonable price - Compatible with DVBViewer with pay channels - Compatible with Windows 7, 64bit (I think this will not be an issue) Any information would be appreciated. Especially, if you live in Finland and have some kind of a card that is working with pay channels, it would be great to know which one you do have! Thanks in advance! EDIT: Oh yeah.. almost forgot.. Also one problem with the Anysee is that the picture hangs if I try to run a game of some sort at the same time. The TV-picture is running on my second monitor and game on the primary. Edited August 28, 2012 by Porris Quote
Griga Posted August 28, 2012 Posted August 28, 2012 Expensive, but successfully in use and recommended by many users: http://shop.digital-devices.de/epages/62357162.sf/en_GB/?ObjectPath=/Shops/62357162/Products/091203 Quote
Porris Posted August 28, 2012 Author Posted August 28, 2012 Thanks for reply.. And the link reminded me about the next issue I have.. I only have PCI slots available. My graphics card reserves 3 slots, covering all PCIe -slots. Any idea for PCI card that would suite the purpose? Also USB in panic is ok. Quote
p0ney Posted October 13, 2012 Posted October 13, 2012 Hi there, I'm also currently searching a new DVB-C card in order to replace my Anysee E7 USB DVB-C. I must advise you on quality of Anysee products, I bought two Anysee E7 from past 2 years and both are dead after an electric cut. The quality is poor for an expensive hardware. Before I was using a Technisat Cablestar with CI slot and it always works. Moreover, i'm wondering which of these cards are the best : - TBS6618 PCI-E DVB-C - Mystique CaBiX-Xpress DVB-C PCIe - DVBSKy C2800E DVB-C PCIe Thank you Quote
