Blue Fishey Posted August 31, 2012 Posted August 31, 2012 (edited) Any one tried ? I am and not working well, channel scan only scan the highest freq, needed to install DirectX9 !!! running 4.9.6.20 Help or ideas Blue Edited August 31, 2012 by Blue Fishey Quote
fxv1 Posted August 31, 2012 Posted August 31, 2012 Yes I tested a while back and all worked fine ...nothing different to w7 64bit that I could detect. Frank Quote
Blue Fishey Posted August 31, 2012 Author Posted August 31, 2012 did you install Directx 9 ? I am running a BG BGT3600 with 8.1.1.2 it is using the MCE tuner but it finds no channels Vista works ok Blue Quote
Shivan Posted September 1, 2012 Posted September 1, 2012 (edited) Hi! I'm using Windows 8 x64 final DVBViewer 4.9.6.20 Recording Service 1.20 PCTV Quatro Stick USB I found over 400 channels. Using cable TV (Germany - KabelBW). I can watch TV, but I often have mpeg artefacts at the beginning, when watching TV. After installing DX websetup (9.29.1974) it no more reminded me to install DirectX. Additionally I had to install an MPEG2 decoder. I installed ffdshow and WinDVD - currently testing which one is better... When installing ffdshow, don't forget to ENABLE mpeg2 codec (default disabled). Hope this helps. Shivan Edited September 1, 2012 by Shivan Quote
trifon33 Posted September 13, 2012 Posted September 13, 2012 (edited) Hi, The final version W8 RTM is perfectly working on Intel Ivybridge w DVBViewer 4.9.6.2 I found the previous version "release preview" not working very well... I suspect this issue is in fact W7 64 including all updates plus special starting GUI for tactile display plus some little features making life easier.... I have installed Lavfilter audio+video..no problem. that fiters set is by far one of the best I have tested... Config: ASUS MB B75 Pentium G620 Anysee E7 S2 Twintech USB DVB-T UT30 Especialy for all PC running XP, the very attractive launching price for the update is to be considered.... The question for W7 users is is it worth the upgrade??? Edited September 13, 2012 by trifon33 Quote
Huigie Posted October 28, 2012 Posted October 28, 2012 I use DVB-C. When I press scan to scan for channels the system restarts with a kernel security check failure .That on a clean install Win8 x64/Terratec H7. Quote
Lars_MQ Posted October 28, 2012 Posted October 28, 2012 That is a driver issue. Is the H7 driver you use certified for windows 8? Quote
