A.M. Posted September 1, 2012 Posted September 1, 2012 Hi. The latest RTSP addition is really nice feature. But I faced a problem when tried to watch the stream on another PC in my home network. Although I checked LOCAL access option in the RS installer I couldn't connect to the stream from any other computer except the computer running RS. But with windows firewall disabled connection was successfull. So I checked inbound firewall rules and modified 2 RS rules to "Public+Private" profile. After that the connection became successfull even with windows firewall on. I guess the installer should be updated.
A.M. Posted September 1, 2012 Author Posted September 1, 2012 Two windows firewall rules for recording service, one for UDP and one for TCP. Field "Profile" was set to "Public" by the installer, I needed to set it to "Private+Public".
Lars_MQ Posted September 1, 2012 Posted September 1, 2012 The installer doesn't change anything there. It only adds the RS to the local applications rules.
A.M. Posted September 2, 2012 Author Posted September 2, 2012 Anyway this action results in adding two firewall rules and these rules are not enough for proper work (on my PC at least).
