hoto44 11 Posted September 16, 2012 (edited) ..a few fixesand design adjustments: skin updated 15-Feb 2013... Hello, here is my newest OSD-SKIN: CCM (Confluence/Concinnity - Mix). I always liked Conncinnity 3D but I am more a fan of full overlay skins like my Confluence-X skin: so here is the solution - a mix of both. Please note: skin contains MR.SkinHelper functionality (BluFuzz - thanks to SnoopyDog). So you need the MR.SkinHelper plugin to be installed: http://www.DVBViewer...d-skin-blufuzz/ For CCM you need the font concinnity (included in fonts folder of the skin) installed on your system. Skin contains also alternative files for home (home - Kopie.xml) and myhome (my home - vertical.xml). If you want to use them make a copy of the skin and replace the original filesand change theme back to home and myhome. Installation: basically like any other skin . The files from (home-) images 1 and 2 are to be copied back in the images folder of the skin.. In addition following plugins are required: X-skin-plugin by Xice http://www.DVBViewer...attach_id=25193 Also you need miniepgvars-plugin. It shows the sattelite frequenz and strength in mini-epg Additionaly last.fm plugin (MyScrobbler-randomartistimage in all screens available) from amontillado. MyMovies, TV Man, neutrinocl, online and online mediathek are also supported by CCM. I hope you will enjoy this skin. Home images are personell favour and can be changed of course. Please see also my other skins for installation: http://www.DVBViewer...sd-skin-e-x-bw/ http://www.DVBViewer...kin-experience/ http://www.DVBViewer...in-evolution-x/ http://www.DVBViewer...n-mod-v2-final/ http://www.DVBViewer...231-reflex-bbw/ Enjoy. hoto44 CCM.zip images1.zip images2.zip Edited February 15, 2013 by hoto44 Quote Share this post Link to post
Vroniefan 1 Posted September 25, 2012 nice gute arbeit hätte aber 2 anmerkungen: - bei my series ist die schrift im "list View" was meist unmöglich zu lesen ist kann man das ändern ? - gibt es das hauptmenü vielleicht auch in senkrechter ausrichtung? mfg Vroniefan Quote Share this post Link to post
jerbi mohamed 0 Posted February 13, 2013 i have this problem on the osd Quote Share this post Link to post
hoto44 11 Posted February 15, 2013 ...will post an updated skin file in first post which should fix this issue. hoto44 Quote Share this post Link to post
Mr_dj 0 Posted May 3, 2016 please why my miniepg is always transparent ?? Quote Share this post Link to post
Gioxy 7 Posted May 4, 2016 please don't crosspost; you answer is here Quote Share this post Link to post
gaedar 0 Posted May 18, 2016 <Hallo,sehr schönes Image .Nur das bei mir der Hintergrund des Mini EPG Transparent ist ,läßt sich auch mit den Transperenzregler nicht beseitigen .alle anderen Anzeigen z.B. Sender EPG werden richtig angezeigt. Quote Share this post Link to post
