krasno Posted September 16, 2012 Posted September 16, 2012 (edited) Hello Background info: My old PC works flawlessly.. but it is time to use the new PC that I bought some time ago actually.. so NOW it is time to.. and let the old serve as back-up or something... And I have come that far now that everything works, ONLY one "minor" problem seriously gives me grey hairs. If I try to store the paths in MyMovies under settings ..I can't.. I can press add, and find the movie folders and name them, but when I press "OK" the info is not stored as usual. I can acess the folders in all other ways, also from DVBViewer- and start playing movies and so on. no errrors anywhere to see.. I have tried everything I can even think of, but nothing helped. The new PC is 64bit the old 32 bit, but to my opinion that should not be a problem.. I use the latest version dvbviwer 4.9.6.20 (not beta) and latest recordservice 1.21.2 I also have tried to share folders and you name it to all users on the PC and have checked folders are not hidden or something. I am logged in as administrator, and ahve tried to start Dvbvwiever as administrator also, but nothing helps. Only thing I can think of myself is to re-install dvbvwiever after I have deleted the installation folders totally, but before i do that I would like to find out if any one out there have any idea what can be wrong. so I don't have to delete everything, if you understand If support.zip is needed please let me know, the new PC is not connected at the moment and this is written from the old PC.. ! I think it is not a DVBViewer problem but maybe a Windows problem, but not 100% sure.. it is only what I think. Thanx for any good ideas I spend all day yesterday to mess with the problem. supporttool.zip added support.zip Edited September 16, 2012 by krasno Quote
