daffy Posted October 17, 2004 Posted October 17, 2004 It's quite nice to have EPG data if / when it is present - unfortunately, EPG data may not always be present because, for instance, some channel has not been tuned to for a long time. Lack of EPG data in turn means that I cannot reliably use the EPG as a, well, program guide. Suggestion: Provide functionality that retrieves EPG data for all stations / stations in the favourites list, across all transponders. The software never should automatically run a "Full EPG update", because it will require switching over a variety of transponders and thus take a while. The only problem that I see at the moment is finding criteria to decide when scanning for EPG data on a transponder should be stopped. One approach would be stop scanning (or timing out) after a fixed amount of time, another could be to stop updating after EPG data for [now] through [now + 12 hours] has been received for all (or favourite) channels on a transponder. Since I have no idea how EPG data is streamed, I cannot tell whether any of these approaches would be feasible. For the record: I do not use TV magazines and I'd drop TVgenial the very moment I could get more complete EPG data through DVBViewer. Quote
Klausing Posted October 17, 2004 Posted October 17, 2004 here in the forum exist a small VB-script which tune all defined station and than you have EPG on all this stations. Try boardsearch. Quote
daffy Posted October 17, 2004 Author Posted October 17, 2004 Ah, another wonderful hack made by griga :-) Well, yeeeeees. That would do it - but - I have to manually define the channels in yet another place - The script is "dumb" as it looks for station, not for transponders (and, I believe, EPG data is sent per transponder. not per station); that wastes a bit of time Perhaps writing a plugin for DVBViewer would work, too: collect all transponders that need updating, then, with audio and video off, switch to any one station on a transponder. So, why don't I write that plugin? Well, compare Description: DVBViewer Plugin SDK ( 3396 Downloads ) » Version: 1.99R6 » Size: 54 KBytes » Last Updated: 25.06.03 and DVBViewer 2.2 RC1 (September 2004?) Besides, I recall reading that plugins do not have access to the list of channels (which would be required). Quote
Klausing Posted October 17, 2004 Posted October 17, 2004 If you have questions to the SDK please ask Christian in DVB - The technique behind and I'm shure Christian will answer you. I'm not a programmer (and i believe this is the best for betatester because programmer have their own train of thoughts ). But all transponders should be inside of the transponder.ini ! Maybe this help. Steffen BTW: mein deutsch ist bei weitem besser als mein englisch, hab da nen Hinweis bekommen ... Quote
