JanoHak Posted October 3, 2012 Posted October 3, 2012 I would like play live streem from dreambox (enigma2)DM800SE using Raspberry / XBMC and DVBViewer. Is it possible? DVBViewer could be install to XBMC player. I did not found dreambox on devices list. Is there some HowTo for XBMC / Dreambox solution? Thanks Quote
Tjod Posted October 3, 2012 Posted October 3, 2012 You would need a Hauppauge HD PVR to get the signal from the DM800SE into the Windows PC with the Recording Service on it. http://www.DVBViewer.tv/forum/topic/46369-hauppauge-hd-pvr/ http://en.DVBViewer.tv/wiki/Category:DVBViewer_Recording_Service Than you need someone to ports "DVBViewer Recording Service PVR" to ARM (Raspberry Pi) an at lest MPEG2 licence (without it MPEG2 decoding will not work. But im not sure if it works with it). http://forum.xbmc.org/showthread.php?tid=140645 http://www.raspberrypi.com/ But over all, I think this is not a good solution. Because if you like to watch TV you need a DM800SE and a Hauppauge HD PVR and a Windows PC and a Raspberry Pi. Better solution connect the DM800SE to the monitor or by a TV card an put it in a PC and connect the PC to the monitor. Quote
JanoHak Posted October 3, 2012 Author Posted October 3, 2012 Looks a bit complicated :-( Raspberry / XBMC working with licence fine. It is easy to play video from internet as well as recorded files from dreambox HDD in .ts format or files from NAS. Why I need PC in the middle? Should be possible to go directly! Now I am thinking about chance to play HDD permanent timeshift file from dreambox. Crazy, but IDEA :-)) My project is about to connect second other room TV by WiFi only without cabling. It is real now and rest problem is live TV program it does not matter if same for both TVs. Quote
Tjod Posted October 3, 2012 Posted October 3, 2012 Why I need PC in the middle?Because DVBViewer and Recording Service are only working on Windows. If you are looking for a solution without DVBViewer (RS), you should ask in a dreambox or XBMC forum. Maybe there are other solutions. Quote
JanoHak Posted October 3, 2012 Author Posted October 3, 2012 Thanks for support. I was confused becouse some Wiki wrong information. Quote
playboy Posted October 3, 2012 Posted October 3, 2012 na so aussichtslos sollte es wiederum nicht sein. die E2 Box hat ja immerhin n Webif. und von daher läst es sich auch problemlos über zB. vlc player streamen.http://192.168.178.41:8000/web/stream.m3u?ref=1%3A0%3A1%3A15EC%3AC9A%3A3%3AEB0000%3A0%3A0%3A0%3A kommt da zB raus.Wäre also evtl da es ja IP basierend ist möglich. Habe es aber noch nie getestet. Quote
