Martin-UK Posted October 26, 2012 Posted October 26, 2012 Hi, Sorry for the newbie question, but I gues i'm in the right topic area I'm having trouble picking up bbc hd and not sure how to scan for it using DVBViewer pro (v4.9.6.20), the details are here according to a bbc website but not what I put in the scanner settings? Astra 1N (28.2° East) Transponder 50 Frequency: 10.84700 GHz Vertical polarisation Modulation: DVB-S2, 8PSK Symbol rate: 23.0 Mbaud FEC 2/3 Transport Stream ID: 2050 Channel SID BBC HD 6940 BBC One HD 6941 Thanks in advance for you help. Quote
Griga Posted October 26, 2012 Posted October 26, 2012 You need an up-to-date transponder list for Astra 28° East (attached). 1) Store it in the Transponders subdirectory of the DVBViewer Configuration Folder (see Help -> Configuration Folder in DVBViewer). 2) Relaunch DVBViewer. 3) Select the transponder list in the scanner window ("Astra/Eurobird 28.2°E") and scan. Astra 28E.ini Quote
Martin-UK Posted October 27, 2012 Author Posted October 27, 2012 Thanks for the reply, I tried this but didn't seem to make any difference, on the scan what do I set the DiSEqc to? also do I level the group set to A? Thanks for your time Quote
QBox User Posted October 27, 2012 Posted October 27, 2012 Select 10847 MHz as the start frequency and click "Scan Frequency". DiSEqC setting only matters if you have a multi-satellite system. You can leave group as A if you only have one tuner. The DVBViewer Scan facility is of limited use. Download TransEdit from the members' area and use that instead. Quote
