BlueShine
hoto44
Hello,
here is a complete remake of: BlueShine - its called now: BlueShine - Titan white
Please note:
BlueShine contains MR.SkinHelper functionality (BluFuzz - thanks to SnoopyDog).
So you need the MR.SkinHelper plugin to be installed: http://www.DVBViewer...d-skin-blufuzz/
For BlueShine you needs the font AeonMain and Sony Sketch EF (included in fonts folder of the skin) installed on your system.
Installation:
basically like any other skin . The files from images 1 and 2 folders are to be copied back in the images folder of the skin.
In addition following plugins are required:
X-skin-plugin by Xice and Conncinity plugin
Also you need miniepgvars-plugin. It shows the sattelite frequenz and strength in mini-epg.
Additionaly last.fm plugin (MyScrobbler-randomartistimage in all screens available) from amontillado.
MyMovies, MySeries, TV Man, neutrinocl, online and online mediathek are also supported by BlueShine.
I hope you will enjoy this skin.
Home images are personell favour and can be changed of course.
Please see also my other skins for installation:
http://www.DVBViewer...concinnity-mix/
http://www.DVBViewer...sd-skin-e-x-bw/
http://www.DVBViewer...kin-experience/
http://www.DVBViewer...in-evolution-x/
http://www.DVBViewer...231-reflex-bbw/
http://www.DVBViewer.tv/forum/topic/53033-polaris/
Enjoy it.
hoto44
P.S.:
one wish @ Mr. Hackbart: would it be possible to get the OSD skin selection
from DVBV options into the skin OSD (like in XBMC). I have in the meantime so many skins
and that feature would be really handy.
BlueShine - Titan white.zip
images1.zip
images2.zip
Edited by hoto44
Published today (9th Dec. 2012) final version. Contains skin design changes en detail, re-design of a couple of used images and bug fixes.
Kind regards
hoto44
..alterative my mini epg1.
Just replace the attached xml.file in the skin folder.
hoto44
myEPG1.xml
  • 10 months later...
Hello,
published today in the first post a complete remake of: BlueShine - its called now: BlueShine - Titan white
Kind regards
hoto44
