fxv1 Posted January 1, 2013 Posted January 1, 2013 Hi, I need some guidance as to how add another folder to the recording Service. C:\FXV300\Recording Folder 1765.30 GB 296.08 GB C:\FXV300\Video 1765.30 GB 296.08 GB I have already added the second folder to the recording Service ( as above) but its' contents do not appear on the recording list. I have Rebuild Video library DB via the Tasks in RS but nothing appears. I have looked at the wiki but could not find anything. Regards RS is there any way to edit the channels that appear, for example I have 7 or 8 entries for channel 4, how can I delete them or make just make a list of channels I am interested in. Cheers Frank Quote
McenterFreak Posted January 1, 2013 Posted January 1, 2013 Regarding channels: Edit them in DVBViewer. Stop Recording Service, start Recording Service. Then the changes will appear in Recording Service. I have made a channel list called Favorites. In Recording Service web interface upper left corner you can choose which channels should appear in the TV Guide Quote
majstang Posted January 1, 2013 Posted January 1, 2013 Hi, I need some guidance as to how add another folder to the recording Service. C:\FXV300\Recording Folder 1765.30 GB 296.08 GB C:\FXV300\Video 1765.30 GB 296.08 GB I have already added the second folder to the recording Service ( as above) but its' contents do not appear on the recording list. I have Rebuild Video library DB via the Tasks in RS but nothing appears. I have looked at the wiki but could not find anything. Regards RS is there any way to edit the channels that appear, for example I have 7 or 8 entries for channel 4, how can I delete them or make just make a list of channels I am interested in. Cheers Frank Video library DB and the Recording DB is not the same thing (different databases). Use Refresh Recording DB instead. If that doesn't work immediately a stop and restart of RS could be necessary followed by a Refresh Recording DB. Quote
fxv1 Posted January 1, 2013 Author Posted January 1, 2013 Video library DB and the Recording DB is not the same thing (different databases). Use Refresh Recording DB instead. If that doesn't work immediately a stop and restart of RS could be necessary followed by a Refresh Recording DB. Many Thanks, that sure has found most of the files apart the ones which were not recorded using DVBViewer. Frank Quote
