Guest Lars_MQ Posted October 24, 2004 Posted October 24, 2004 osdWeather Plugin 0.95 --------------------- Weather data provided by weather.com Installation: ------------- ATTENTION the osdWeather plugin needs newOSD 0.95 and DVBViewer 2.3beta. You need also a internet connection for the city setup and to download the weatherdata. There are two zip files: osdWeatherImg.zip and osdweather.zip. Unpack both into the DVBViewer path. Installation instruction in the readme.txt. Download as usally in the membersarea have fun lars Quote
mighty Posted November 5, 2004 Posted November 5, 2004 OK, this seems to be my luck evening... Now newOSD works perfectly, the same for DVBViewer Filter, BUT when I try to open osdWeather I get this error: ExceptionError in Modul osdWeather.dll bei 00008B32 Any ideas? Quote
Guest Lars_MQ Posted November 6, 2004 Posted November 6, 2004 You installed the osdweatherimages also? I tested it with the test newOSD version, everything seems to be fine. Which OS/Internetexplorer Version do you use (you need at least IE 5.5, I think for XML Support) lars Quote
mighty Posted November 6, 2004 Posted November 6, 2004 I installed osdWeatherimg (the images are under Images\weather folder) and I tried with osdWeather95 in the download area, with osdWeather95a and c I found in your post in the german section but they all seem not to work! I'm under WinXP SP2 and I use FireFox 1.0RC1. Let me try with IE as the default browser... Quote
Guest Lars_MQ Posted November 6, 2004 Posted November 6, 2004 No you don't need to change your browser. XP should be ok, it has the needed xml support. slowly I'm running out of ideas lars Quote
Guest Lars_MQ Posted November 6, 2004 Posted November 6, 2004 One thing. Is there a DVBViewer.log file in the DVBViewer dir? If yes could you post it? The DVBViewer logs every error and most of the plugin errors, maybe this shows something. lars Quote
mighty Posted November 6, 2004 Posted November 6, 2004 (edited) It's full of this: 06/11/2004 9.38.58 EAccessViolation raised by instance frmMain of class TfrmMain at 02B8DD08:Zugriffsverletzung bei Adresse 02B8DD08 in Modul 'osdWeather.dll'. Lesen von Adresse 00000000 I attach the log btw. DVBViewer.log Edited November 6, 2004 by mighty Quote
Guest Lars_MQ Posted November 6, 2004 Posted November 6, 2004 ok, just to check: try moving the osdgames.dll out of the plugin folder. if you use osdtimeline.dll move it also out of the plugins folder. keep only the newOSD.dll and the osdweather.dll. (and of course your other not osdrelated plugins). lars Quote
mighty Posted November 6, 2004 Posted November 6, 2004 Nothing! Just to be sure, I uninstalled everything and reinstalled from scratch, with just newOSD, osdWeather95c and isdWeatherimg. Still it's not working... Quote
Guest Lars_MQ Posted November 6, 2004 Posted November 6, 2004 Ok with a lot of testing from mighty (thanks) I fixed a problem that can happen on some international (or none german) windows systems. I attach a fix for it here for some more testing. It only works, if you installed the osdweatherimg.zip from membersarea and also the osdweather.zip plugin itself. It won't work if you only use the attached file! There is now also an option for automatic updating from the internet. Note for installation and the first download of weatherdata you need a internet connection. If you decide not to use automatic update, you can force an update by pressing the reload button (within the half an hour limit). Also included is an english skin. Just copy the two skin files to your DVBViewer\images\weather folder. A hint for my helper mighty: You can localize the skin yourself if you want, just replace the text= tags in the skin where no #-sign is. (It's hard for me to explain, just have a look into the two skin files and you will see ) The weather data itself is english, there is for now no easy way to translate them, sorry. lars osdWeather.zip Quote
Griga Posted November 6, 2004 Posted November 6, 2004 with a lot of testing from mighty (thanks) I fixed a problem Good to know there are users who are really willing to help us to make the stuff better and more reliable (instead of mere complaining). Quote
mighty Posted November 7, 2004 Posted November 7, 2004 Well, I paid 15€ for this software; it's my interest to make it better!! A part from jokes, I wouldn't be able to create a plugin, but if you need some testing or translating, I'm here! Quote
mighty Posted November 7, 2004 Posted November 7, 2004 (edited) This is a first revision of the italian translation for osdWeather. There are still some things I can't change though, such as: - the label on the buttons - in the "Wind" filed, the "von" and "bis" (when it says: von N bis 8 Km/h) but I think they're enbedded in the dll (or maybe I'm just too tired and I missed them ). I was also thinking if it is possible to translate the names of the days and, I'm fool, I know, the "Partly Cloud" and stuff, as I saw they are stored in the XML. Maybe it's possible to change them before storing them or before displaying them (guess it would be wiser before storing). Anyway, I'm just thinking loud, if I'm saying bullshit, just don't care me! weather.skin Edited November 7, 2004 by mighty Quote
Guest Lars_MQ Posted November 7, 2004 Posted November 7, 2004 Very good, thanks. That's right, some things are "hardcoded". It's quick and dirty hack to get a little bit of international flair into the plugin For the next version there will be a possibility to translate everything including the weather data. And don't bother trying to translate the xml, it gets overriden everytime you download the weatherdata so your work will be lost lars Quote
mighty Posted November 7, 2004 Posted November 7, 2004 (edited) And don't bother trying to translate the xml, it gets overriden everytime you download the weatherdata so your work will be lost I never thought that. I said "before it's written" or "before it's displayed" Anyway, we'll wait for the next version! Edited November 7, 2004 by mighty Quote
Guest Lars_MQ Posted November 7, 2004 Posted November 7, 2004 Well, I wrote the text before I had my second coffe Quote
mighty Posted November 7, 2004 Posted November 7, 2004 Lol! Don't worry, I still need to wake up too! Quote
