fxv1 Posted January 15, 2013 Posted January 15, 2013 Hi, just have a few questions which would be great to find the answer to but are not show stoppers. 1) On many occasions when watching BBC HD channels and one program stops, you get some ads or interlude and the sound disappears. If I perform a graph rebuild the sound will play. 2) files recorded as filename.ts files will play great on DVBViewer but will have no sound in MicrosoftMediaCenter. 3) VLC will stutter with video with the same video that DVB plays perfectly. support.zip Quote
Griga Posted January 15, 2013 Posted January 15, 2013 On many occasions when watching BBC HD channels and one program stops, you get some ads or interlude and the sound disappears. Maybe AC3 2.0 <-> 5.1 changes? Maybe the audio decoder selected for AC3 (Cyberlink) doesn't like it? I would try AC3 Filter (32 bit version for DVBViewer!). Quote
Griga Posted January 15, 2013 Posted January 15, 2013 Seems you are receiving DVB-T, not DVB-S (you didn't mention it...). In this case the AAC audio decoder may be relevant. I would select the DivX AAC decoder (already present in you system). Quote
fxv1 Posted January 15, 2013 Author Posted January 15, 2013 Many thanks Griga, I will give that a try. (That will be in the AAC Audio Decoder Field I presume?) Yes it was DVB-T ....is the audio different on DVB-T to DVB-S? Quote
Derrick Posted January 16, 2013 Posted January 16, 2013 .is the audio different on DVB-T to DVB-S? ..no, not necessarily. But in the UK you have DVB-T2 which allows and uses aac audio for HD channels Quote
QBox User Posted January 16, 2013 Posted January 16, 2013 (edited) BBC HD on satellite switches to multi-channel audio on Preview. BBC One HD does this during regional news interludes. It seems likely that terrestrial would do the same, though of course encoding is different. These interludes are a good way to test audio set-ups. The Preview includes a test for audio delay. Edited January 16, 2013 by QBox User Quote
fxv1 Posted January 16, 2013 Author Posted January 16, 2013 Thanks everyone for the responses...yes noticed that DVB-S2 BBC 1 HD is on AC3 and DVB-T2 is AAC. Frank Quote
