eXperience (Titan Theme)
hoto44
Hello,
here is my newest OSD-SKIN: eXperience (Titan Theme).
This skin is based on my eXperience skin using a view design themes of MEPO skin Titan.
Please note:
eXperience (Titan Theme) contains MR.SkinHelper functionality (BluFuzz - thanks to SnoopyDog). So you need the MR.SkinHelper plugin to be installed: http://www.DVBViewer...d-skin-blufuzz/
For eXperience (Titan Theme) you need the font AeonMain (included in fonts folder of the skin) installed on your system.
Installation:
basically like any other skin .
The files from (home-) images 1 and 2 are to be copied back in the images folder of the skin.
In addition following plugins are required: X-skin-plugin by Xice http://www.DVBViewer...attach_id=25193
Also you need miniepgvars-plugin. It shows the sattelite frequenz and strength in mini-epg.
Additionaly last.fm plugin (MyScrobbler-randomartistimage in all screens available) from amontillado. MyMovies, MySeries, TV Man, neutrinocl, online and online mediathek are also supported by experience.
Home images are personal favour and can be changed of course.
Please see also my other skins for installation:
http://www.DVBViewer...concinnity-mix/
http://www.DVBViewer...sd-skin-e-x-bw/
http://www.DVBViewer...kin-experience/
http://www.DVBViewer...in-evolution-x/
http://www.DVBViewer...n-mod-v2-final/
http://www.DVBViewer...231-reflex-bbw/
Enjoy it.
hoto44
eXperience (Titan Theme).zip
images1.zip
images2.zip
  • Like 3
In der Timeline wird die Aufnahme nicht angezeigt durch den roten Icon.
  • Like 1
  • Thanks 1
...please copy attached image file into the images folder of the skin.
record_button.zip
Edited by hoto44
  • Confused 1
  • Sad 1
Hello I can't seem to download the x skin plugin. When I click to download it directs me here http://www.DVBViewer.tv/forum/. Also when I download the images 1 and images 2 do I just copy and paste everything in both of these folders to the images folder in the skin. Is this correct? Or should I only copy one image folder?Should I copy the images folder or just the stuff inside? Also please see attached photo. The epg is see through and it shouldn't be. The same thing happens with all of your skins so I am pretty sure I am doing something wrong. Is this because I don't have the x-skin plugin? Any help would be appreciated. https://lh3.googleusercontent.com/-m3JIS33OlrE/UTTThyjDyaI/AAAAAAAAAE0/RmX-hcGMYsw/s800/titan%2520menu.png
its ok. I figured it out.
Edited by cundogg
  • 3 months later...
Hey, i just got the same problem as cundogg (as seen on his picture), but i cant figure out how to get it working...
can anyone help me?
can anyone help me?
Ok i got it. I forgot to install the MR.skinhelper Plugin :glare: but now it works perfect!
Is it possible to change the OSD sounds on a different audiorenderer ? I use a TV and it would be great if the sounds also could played on my TV instead over the PC speakers...
This has nothing to do with this OSD Skin.
And no it is not possible the sounds use the Windows default sound device.
To disable the sound remove the sound folder from the OSD Skin.
It has. Because This OSD Skin uses this sounds.. Anyway thank you for the hint!
  • 2 years later...
please can some one tel me where i put the floder image1 and image2 thank you :)
Hi Mr_dj,
as writed in red in the first post by the skin author itself, the content of this two folders (without the folders!) is to be copiend in the "images" folder of the skin...
:bye:
i have another question please why my EPG is transparent ..
OSD transparency level can be managed in "Settings / Options / OSD General" with the "VMR Transparency" slider, where 0% mean solid OSD...
:bye:
Edited by Gioxy
  • 1 year later...
  • 1 month later...
  • 8 months later...
Moin hoto44,
ich hab jetzt etliche Skin's durchprobiert, und bin immer wieder bei diesem hier hängen geblieben.
Gibt's dazu auch einen deutschen Thread (hab zumindest nichts gefunden), oder darf ich mich hier austoben ?
kein Problem in Deutsch hier.
Super,
Wie gesagt, hab ich jetzt etliche Skin's durch, und der "eXperience (Titan Theme)" gefällt mir wirklich am besten.
Allerdings würde ich mir ein paar kleinere optische, und (da ich meinen HTPC mit der Maus bediene) auch funktionelle Anpassungen wünschen.
Leider hab ich selber vom erstellen eines Skin's absolut keine Ahnung.
Wärst du evt. bereit, mir da noch ein paar Sachen anzupassen ?
Das erste wäre, das bei mir aus irgend einem Grund das MiniEPG-Fenster (heist das so?) nicht "transparent-grau" unterlegt ist,
und das ich auch gerne auf den Timeshift-Balken am oberen Rand verzichten würde.
Und kann man die Systemsound's auch abschalten ?
Was ich mir aber besonders wünschen würde, wäre ein Popup mit den Filminfos,
wenn ich unten auf den derzeit laufenden, oder den folgenden Filmtitel klicke.
So etwa:
Ein weiteres "nice to have" wäre, wenn bei AC3-Ton rechts neben dem Dolby-Logo noch angezeigt würde,
ob der AC3-Ton in 2.0 oder 5.1 vorliegt.
So z.B.
Wäre wirklich super nett, wenn du mir das so anpassen könntest.
Gruß: goldfield
Edited by goldfield
Das mit den Systemsounds hat sich erledigt.
Das das MiniEPG-Fenster nicht grau hinterlegt ist, hatte scheinbar schon mal jemand.
Hab das mit dem VMR Transperency Slider ausprobiert.
Das MiniEPG bleibt komplett durchsichtig.
Edited by goldfield
....bitte diese Datei im Skin verwenden. Sollte das Mini Epg fixen.
myMiniEPG.xml
Bingo !
Das erste Problem wäre damit schon mal erledigt.
Danke sehr.
Kann ich die Timeshift-Leiste am oberen Rand auch irgendwie löschen ?
Passt:
Besten Dank.
Und ist das mit den Filminfos auch machbar ?
Am 12.8.2018 um 17:20 schrieb goldfield:
So etwa:
So sieht das bei mir z.B. in Kodi aus
Mit deinem Skin bin ich aber nahe dran, Kodi  wieder rauszuschmeißen,
und wieder alles mit dem DVBViewer zu machen.
Edited by goldfield
Das mache ich leider nicht mehr. Ich habe mir eine VU+ Linux Box als Receiver/Mediacenter gekauft und bin mehr als glücklich mit dieser Entscheidung.
OSD, Animationen, Plugins, Zappen alles top und schnell out of the box. Kein PC Gewürge und Gehäule der Grafikkarte mehr.
Und Kodi und Mediaportal habe ich schon 100mal probiert und frustriert wieder vom PC nach Crahs gelöscht.
Naja,
Die Video-Datenbank von Kodi finde ich schon ziemlich gut gelungen.
Aber Live-TV  wird bei Kodi wohl etwas vernachlässigt.
Da hat der DVBViewer für mich deutlich die Nase vorn.
Das wirft meine Hoffnungen wieder über den Haufen.
Mit ein par kleinen Anpassungen deines Skin's wäre der DVBViewer das perfekte Mediacenter für meine Bedürfnisse.
Leider bist du scheinbar auch einer der wenigen "Skin-Entwickler" die hier überhaupt noch aktiv sind.
Oder hättest du einen Tip, wer mir da noch weiter helfen könnte.
(sofern du überhaupt damit einverstanden wärst, wenn jemand anders an deinem Skin rumbastelt).
Da von den Entwicklern scheinbar kein Wille da ist, das OSD mit zusätzlichen Funktionen/Animationen aufzuwerten, habe ich keine Lust mehr.
Ich kann Dir nur den DVBViewer Skinner empfehlen. Damit habe ich alles selber gelernt und angepasst.
Ich würde mir wünschen, dass andere DVBViewer Freunde Skins weiter entwickeln. In diesem Punkt ist hier leider alles tot.
Meiine Skins kann jeder verbessern der will.
Ich werd mir den DVBViewer Skinner nochmal in Ruhe ansehen.
Aber auf den ersten Blick wird mir das wohl doch etwas zu hoch sein.
Aber bei einer Sache könntest du mir vielleicht doch noch mal helfen.
Ich versuche gerade, mir das Home Menü mit dem Menü Editor an meine Bedürfnisse anzupassen.
Einige Menüpunkte hab ich schon erfolgreich zugefügt, und auch ein paar nicht benötigte entfernt.
Jetzt werden mir aber immer noch die Menüpunkte "Sleeptimer", "Neitrinocl", und "Online" angezeigt,
obwohl diese im Menüeditor garnicht aufgeführt werden.
Kannst du mir erklären, wie/wo ich die löschen kann?
Edited by goldfield
Hat sich erledigt.
Das waren Plugins, die gelöscht werden mussten.
  • 5 months later...
