daffy Posted October 27, 2004 Posted October 27, 2004 I mentioned this elsewhere, buried deep inside some monster thread - so it's time to repost in a better location: The combination of DVBViewer and the latest 4.3.0 B2C2 drivers does not work reliably. Note: This Applies to both "DVBViewer TE" (perfectly clean) as deployed with the 4.3.0 driver package as well as "DVBViewer 2.3 (beta)" (plugin-infested). Fundamentally, the application will start up, will show some TV, will channel switch a few times - BUT after a few more channel switches, everything is black and silent. It seems as if something is killing the driver itself, as I do have to disable/enable the device in the Device Manager to get audio/video back. I have no idea what might be wrong, unfortunately - perhaps it's W2K3, perhaps it's hyper-threading - no idea, sorry, and I am not really up to playing the driver game at the moment. For now I have reverted way down to 4.2.8 - which has other issues (apparently something is hogging some bus for some time, because opening a new browser window may cause slight, very short stutter in the DVBViewer window). Quote
Guest hackbart Posted October 28, 2004 Posted October 28, 2004 Hi, are you sure? I work with the driver itself since more than 2 weeks. Christian Quote
daffy Posted October 28, 2004 Author Posted October 28, 2004 Pretty sure about my problems and pretty sure about using 4.3.0 ;-) What I question is the overall state of my W2K3 installation - so with the nVidia codecs no longer working with DVBViewer and considering the age of the W2K3 installation, I have decided to reinstall. Everything. From scratch. I'll probably be able to provide more feedback, whichever way, on Sunday (or later - sigh). Quote
marfi Posted October 28, 2004 Posted October 28, 2004 Hi, are you sure? I work with the driver itself since more than 2 weeks. Christian I'm sure. Drivers 4.3 it's an mistake. Moved to trash Quote
mighty Posted October 28, 2004 Posted October 28, 2004 Same problem here. Using 4.3.0 drivers and 2.3 beta, sometimes it works, the most doesn't! I will reinstall everything next week, but I fear nothing will change. Quote
daffy Posted October 29, 2004 Author Posted October 29, 2004 I am writing this message from a mega-clean, fresh W2K3 installation. I am writing this message to tell you that I am not - I repeat NOT - ever going to install 4.3.0 again. Ever. Did I say ever? No? Ok, let me say "never ever again". Frankly, 4.3.0 is wonderful when it comes to lack of robustness, lack of compatibility with two plugins I prefer using, and in general rather persistent when trying to remove it from the system. Alas, that's not exactly what a user (me) likes to see. Quite to the contrary, actually. Net effect: Farewell, 4.3.0 - welcome back, 4.2.8. End of story. Ok, I owe you one example of lack of robustness: With 4.2.8 (and 4.2.11) I could kill the DVBViewer brutally, without any adverse effects. With 4.3.0 I have to disable/enable the driver in order to be able to view TV again. Quote
mittern8 Posted October 29, 2004 Posted October 29, 2004 Hi, are you sure? I work with the driver itself since more than 2 weeks. Christian As I said before: this drivers are a pain in the a**. Gave them another try today and just rolled back to 4.2.11. Tried different progs: DVBViewer TE v1.9.7.200 DVBViewer, most recent Version available from TS DVBViewer 1.9.8 R14 DVBViewer 2.2 RC1 DVBViewer 2.3beta Alt-DVB recent version DVB-Dream 0.8.6 ProgDVB 4.44.1 SkyView Transedit with different source filters (Marfi's, DVBViewer, DVBViewer Classic, Skystar) and different combinations of Directshow filters (mainly Cyberlink A/V, Intervideo A/Cyberlink V, Elecard/Moonlight, AC3filter, DVD Express) under different conditions and with different settings. None of them worked flawless with the new driver. Problems I noticed are with signal strength indication switching problems as mentioned by daffy problems during transponder scanning (same channels/package found twice on different frequencies) A/V running out of sync (most important) Guess TS should do some further investigation and should take it off the site till the probs are fixed ... <offtopic> @ daffy Why do you install 4.2.8 instead of 4.2.11? Does it have any advantages? </offtopic> Quote
daffy Posted October 29, 2004 Author Posted October 29, 2004 4.2.11: Without (!) DVBViewer running, audio playback (for instance in Windows Media Player) has artefacts and distortions every other second or so. Fixed as soon as DVBViewer runs. 4.2.8: No problems. I guess 4.2.11 shows DMA or PCI problems on my system. Quote
kaiser.wilhelm2 Posted October 29, 2004 Posted October 29, 2004 4.2.11: Without (!) DVBViewer running, audio playback (for instance in Windows Media Player) has artefacts and distortions every other second or so. Fixed as soon as DVBViewer runs. This problem seems to be fixed within the 4.3.0 release. I also use the 4.3.0 and it really works without any trouble on my machine (XPSP2). Quote
Guest Oliver Posted October 29, 2004 Posted October 29, 2004 4.2.11: Without (!) DVBViewer running, audio playback (for instance in Windows Media Player) has artefacts and distortions every other second or so. Fixed as soon as DVBViewer runs. 4.2.8: No problems. I second that. Bye, Oliver Quote
schmude Posted October 29, 2004 Posted October 29, 2004 Same problem here. I'm using 4.3.0 drivers and 2.3 beta under WinXP SP2, sometimes it works, the most doesn't ! Short occurance of TV programm, then nothing more (no sound, no video). My system slows dramatically down. Ciao Stefan Quote
Derrick Posted October 29, 2004 Posted October 29, 2004 ..well, I switched between drivers in the last couple of days many times, trying to get another application running. Though not thoroughly testet, I can't confirm what is written here about 4.3.0 and the DVBViewer beta. But I went back to 4.2.8 just in case Quote
mittern8 Posted October 29, 2004 Posted October 29, 2004 4.2.11: Without (!) DVBViewer running, audio playback (for instance in Windows Media Player) has artefacts and distortions every other second or so. Fixed as soon as DVBViewer runs. 4.2.8: No problems. I guess 4.2.11 shows DMA or PCI problems on my system. Well, I noticed that too by playing Audio Media either in MP and WinAmp but I didn't see any connection to the 4.2.11 drivers - good to know. Thanks for that info! @ Kaiser Wilhelm II You know why they never found BSE in Argentinian beef? They simply don't search for. Well, and just for the records, I'm also running WinXP pro SP2. Quote
johnnypeste Posted November 5, 2004 Posted November 5, 2004 I have the same problem with 4.3.0 drivers and DVBViewer 2.2 (video and audio keep freezing!) However the last DVBViewer technisat edition bundled with 4.3.0 drivers seems to work well. But of course i want DVBViewer 2.2 pro I think 4.3.0 drivers gives more signal strenght (sorry if it sounds stupid...) and i don't want to roll back to previous drivers. So, I think I have to wait for either a new technisat driver or a working DVBViewer pro Quote
Derrick Posted November 5, 2004 Posted November 5, 2004 I think 4.3.0 drivers gives more signal strenght.. I experienced the opposite.. the green bar is shorter than with 428 Quote
johnnypeste Posted November 5, 2004 Posted November 5, 2004 And the 428 works well for you with the DVBViewer 2.3 beta? I can't test because i don't have 2.3 beta yet. What about 430, despite less signal...Is it working also? Quote
Hartwig Posted November 5, 2004 Posted November 5, 2004 I have with 4.2.2, 4.2.11 and 4.3.0 ~75%. But with 4.2.8 I have only ~50%. That can't be, because it's the same tuner and so on. The cause must be the calculation of this value. The real signal strenght can't vary by the driver version. The 2.3 beta works will all versions of the driver (on my PC) Quote
johnnypeste Posted November 5, 2004 Posted November 5, 2004 What about 2.2rc1? Is it working too with 4.3.0? Because if 2.3 beta works I will give it a try... I don't believe it will depend so much on the computer... 2.2rc1 was made in September (that is: before 4.3.0) technisat edition was made in October (after 4.3.0) I thinks that's the problem! Quote
Hartwig Posted November 5, 2004 Posted November 5, 2004 yes, it works. (If you use winXP, you gan go back to an earliert driver by the device manager, if it dont work. ) But be careful, the new software from technisat uninstalls the DVD-Express decoders. So you must have other decoders (like NVIDIA, Cyberlink, Intervideo...) in your system or you must install only the new driver by the device manager. Quote
johnnypeste Posted November 8, 2004 Posted November 8, 2004 It's hopeless 4.2.11 freezes audio and video too. And what is worse technisat edition now freezes too... So I went to 4.3.0 and I'm using mytheatre until "DVBViewer pro" works... Thanks Quote
Klausing Posted November 8, 2004 Posted November 8, 2004 @johnypeste: If you dont give us this needed informations we can't help you!!! A driver can't freeze only Audio and Video ! Audio and video is a part of directshow. Wrong settings and bad or incomplete installations can do this! Installed decoder packages can do this too. And freeze is not freeze .... However the last DVBViewer technisat edition bundled with 4.3.0 drivers seems to work well. And thats the evidence, its possible with your system !!! Steffen Quote
johnnypeste Posted November 8, 2004 Posted November 8, 2004 OK Steffen, thanks Here comes the facts! DVBViewer TE bundled with 4.3.0 works well with 4.3.0 driver. dvbviwer pro 2.2rc1 does not. The problem is: audio and video is coming in flashes every 5 or 10 seconds during 1 second, and when I want to record, there is no signal to record and the resulting file has 0 Kb size. It seems that very few bytes are arriving from b2c2 to the prog! In fact, with technisat edition the recording also have problems, but at least I can see video and hear audio, despite a small out of sync... So I think it is not a decoder problem! The stream is not arriving as it should! Sorry for this explanation but I can't do better. I tried all the source filter (Marfi, etc) and all have the same problem. Other guys in this forum reported problems...So I'm not the only one. If you need to ask for anything please do. Thanks again Quote
Derrick Posted November 8, 2004 Posted November 8, 2004 Here comes the facts! DVBViewer TE bundled with 4.3.0 works well with 4.3.0 driver. dvbviwer pro 2.2rc1 does not. yes, you're right, there is an issue concerning the source filter (at least that's what I think ) in combination with the new driver. Though no problems with the beta version and the new push_source_filter.. Quote
johnnypeste Posted November 8, 2004 Posted November 8, 2004 thanks derrick I'm felling much better now So, 2.3 beta works...Is there anything to do to 2.2rc1 to put it working. I would like to give another chance to a nonbeta release because generally I don't like to use beta versions. Quote
Derrick Posted November 8, 2004 Posted November 8, 2004 ..change the driver back again to 4.2.8 or wait for a fix. You could switch to marfi's source filter but I guess, you'll have to get a a new version of the skyac.dll from his site. Quote
johnnypeste Posted November 8, 2004 Posted November 8, 2004 I will search for the new marfi, because i don't think 4.2.8 will resolve my problems. At least 4.2.11 didn't... Quote
Klausing Posted November 8, 2004 Posted November 8, 2004 new version of the skyac.dll You mean SkyAVC.ax !?! Quote
johnnypeste Posted November 8, 2004 Posted November 8, 2004 Derrick Why is Klausing laughing? Skyavc.ax is not good? Quote
Klausing Posted November 8, 2004 Posted November 8, 2004 Derrick wrote skyac.dll and not skyavc.ax! But Marfi have some trubble with 4.30 drivers too ! But i can't see a good reason for using marfis filter. And i can't help you if you don't give needed informations. What is with logMPGDecoder?.... Quote
Derrick Posted November 8, 2004 Posted November 8, 2004 ..you mustn´t take everything seriously I was was wrong Quote
Derrick Posted November 8, 2004 Posted November 8, 2004 But i can't see a good reason for using marfis filter.And i can't help you if you don't give needed informations. Don´t ask silly questions ..there is proof that the old, good combination doesn´t work anymore when switching to 4.3.0 ..however marfi does the job! Isn´t that reason enough? Quote
johnnypeste Posted November 8, 2004 Posted November 8, 2004 Now I'm totally confused I tried to open a mpg file on my disk (completely readable in windows media player) and i get the same problem, Audio and video keeps flashing! it gives a warning when i open the file: record/timeshift is active but i can't disable timeshift!!!!!!!!!!!!!!!!!! Is timeshift screwing the all thing? thanks for the patience Quote
johnnypeste Posted November 8, 2004 Posted November 8, 2004 my decoder is elecard but the problem is the same with all the decoders. Even with hardware decoders...(i have a hplus card) again with technisat edition i can play the file without any problems and with the decoders Quote
Klausing Posted November 9, 2004 Posted November 9, 2004 AGAIN: post needed informations !!!! Thats your last chance to get support from me! I'm not a clairvoyant! Quote
johnnypeste Posted November 9, 2004 Posted November 9, 2004 Klausing Thanks for the worry What extra information do you need!? For me, the DVBViewer incapacity of reading a simple mpg file makes me think that either my system is very bad (not probable since other dvb programs work well) or that I'm missing something in the prog configuration (but in this case my suggestion is to make to prog easier to use: after all I'm just opening a mpg fille!!!!!) Quote
Hartwig Posted November 9, 2004 Posted November 9, 2004 http://www.DVBViewer.com/forum/index.php?s...?showtopic=2210 look especially at point 5 Quote
johnnypeste Posted November 9, 2004 Posted November 9, 2004 I installed DVBViewer in another computer without any dvb card just to see if it can open a mpeg file. The problem is the same. It plays for 3 seconds than it stops for 1 seconds and it plays it again an it stops etc Here goes in attach the files requested I hope you can find the solution log.zip Quote
Griga Posted November 9, 2004 Posted November 9, 2004 Hmm, the setup.ini doesn't contain any version info. Strange... The flashing is usually caused by using an illegal key, or having used it before purchasing the Pro Version and installing it, without entering the new valid key. Dunno wether there are other possible reasons.... Quote
Klausing Posted November 9, 2004 Posted November 9, 2004 It plays for 3 seconds than it stops for 1 seconds and it plays it again an it stops etc In which application you tried to play?If you have this reaction in Windows MediaPlayer you have really a problem in your system. If you have this reaction in DVBViewer , you are using a illegal version! This is a hardcodet feature for all people which want to use DVBViewer without to buy it. Ore you have a bad/wrong key! If you bought a legal version please ask hackbart again for a right key. Steffen Quote
