se1222 Posted March 3, 2013 Posted March 3, 2013 I bought a license for DVBViewer Pro because the v4.9.5 Changelog said: Added: DiSEqC 1.2 support for TechniSat SkyStar eXpress HD with WDM/Network driver. Enhanced: DiSEqC 1.2 support for TechniSat SkyStar eXpress HD and SkyStar USB HD with BDA driver. Now it also works under Windows XP. After installing the tuner’s drivers (BDA + WDM) and DVBViewer Pro 5.0, the DiSEqC 1.2 (TransEdit / Positioner) app works properly. But soon after starting DVBViewer (it can be a few seconds or a few minutes) first DVBViewer, then the whole system locks up. About half a minute after that the computer reboots and Windows reports a serious problem. This happens with both BDA and WDM drivers. I get the same error using DVBViewer TE or TransEdit Preview. The crash also occurs when the tuner has a high input signal. Note: DVBViewer works fine with my DVB-T tuner (AirStar TeleStick 2). Can anyone help? Hardware: Mainboard: Intel DH67CL Chipset: Intel H67 Express Chipset CPU: Intel Core i5-2500 3.3GHz RAM: 4 GB (8 GB) Video: Intel HD Graphics (onboard integrated) Tuners: Technisat SkyStar 2 eXpress HD and Technisat AirStar TeleStick 2 Software: Windows XP Pro SP3 (with all updates) DVBViewer Pro 5.0 SkyStar 2 eXpress HD drivers and video decoder settings: See the attached images! support.zip Quote
