Recording Service 1.24.0.0
xtonys
Hi
Apologies if I have started a thread in the wrong place... I searched for Recording Service 1.24.0.0 bugs, but couldnt find a general place?
I have installed Recording Service 1.24.0.0.
I want to ask if anyone has experienced these problems and how to fix them....
Google Chrome is my preferred browser. When I search a program in EPG, tick the box and click record.... it does not go yellow and does not appear in the timer list.
If I use Firefox, it works.
I have deleted browser history and run ccleaner to delete any cached files related to previous recording service (that worked fine in Chrome)
The record button on this same screen would ideally stay in position. As I scroll down a list of EPG search results, the record disappears.
It would be great to be able to switch audio channels on recordings that are played on either my LG TV or a Sony SMP-N200.
My workaround is to create a copy of BBC HD and BBC1 HD so I have an AC3 channel and and MPEG2/NAR (narration) channel. If I remember I can record the AC3.
Would be nice to switch between audio tracks, but I dont see any options when I select Audio Track from the DLNA streamers I have.
If I play the same recording directly with DVBViewer 5, I get the AC3 track by default.
Im sure there's gonna be some xml file edit to change streaming audio default to AC3, but no idea where....
Thanks for the advice...
I cant upload the support.zip as its 303kb and max single file size is 155.06kb
Edited by xtonys
Actually, I think you have a point there! It would be nicer for sure and easy to accomplish as well :)
Actually, this idea is not that bad. Any takers? it's just a little html and javascript. No need for me to get directly involved. I just integrate it into the setup when it's done... :)
