timetrex Posted March 7, 2013 Share Posted March 7, 2013 Hi, just fiddiling aqbout with the recording service, checking out rtsp... On my pc where DVBViewer and the recording serice is installed I can view rstp channel fine. I am trying to remotely view the stream remotely, can someone advise is there anything else other than 554 port that needs forwarded? tried allowing in firewall but vlc wont stream, no error messages on vlc. thanks tt Link to comment
Tjod Posted March 7, 2013 Share Posted March 7, 2013 http://www.DVBViewer.tv/forum/topic/51714-rtsp-streaming-with-vlc-client-crash-every-20sec-aprox/?p=382223 Link to comment
timetrex Posted March 7, 2013 Author Share Posted March 7, 2013 The stream plays fine on the lan using VLC? I am using both the latest DVBViewer and recording service. I dont get any pictures remotely..which suggests port forwarding/firewall... tbh im not sure of the setup, not sure if I have to add rstp device or does my sat card the rstp device as I have said the stream does play fine locally on vlc. Link to comment
xtonys Posted October 21, 2013 Share Posted October 21, 2013 Hi I have recording service 1.27 I installed the Elgato SAP>IP android app. It finds the RTSP server and can scan channels. It only shows the server as DVB-S only. If i understand the SAP>IP spec, DVB-S2 is included? DISECQ 2 is not included, but there may be ways to change dishes/lnb anyway? For the SD channels I watched on my phone, it seems a more reliable picture and EPG info than Rec Service DNLA... Is there another android app I should using? Thanks for any advice Tony Link to comment
KayDiefenthal Posted October 23, 2013 Share Posted October 23, 2013 (edited) Sat>Ip Spec 1.2 Supports DVBS DVBS2 with diseqc 1.0 and DVBT DVBT2 Edited October 23, 2013 by KayDiefenthal Link to comment
