Nayef Posted March 10, 2013 Share Posted March 10, 2013 (edited) Suggestion for develop timer section : hi all i have more channels same name & multi DVB-S I find it difficult to set recorder channels distribution by multiple devices Attempted use of a "Grope channels" .. channels |A| for (DVB-S 1) ... channels |B| for (DVB-S 2 ) ...& I set that in hardware setting but RS does not differentiate between channels similar names I therefore propose to develop the temporary section : - Rearrange the channels associated with a specific device.in timer section - Put a small box to search for channels. i think that available in DVBViewer Pro ... i hope do that in RS also ... Edited March 10, 2013 by Nayef Link to comment
Tjod Posted March 10, 2013 Share Posted March 10, 2013 Do you speak of channels with a equal name on different sat positions. Or about having one channel multiple times in the channel list? Link to comment
Nayef Posted March 10, 2013 Author Share Posted March 10, 2013 Do you speak of channels with a equal name on different sat positions. Or about having one channel multiple times in the channel list? i mean first channels with a equal name on different sat positions As an example 1 I want recorder (BBC HD) ... this channel only work in Device DVB-S 3 (BBC HD) not work in Device DVB-S 1 & Device DVB-S 2 so i need Determination (BBC HD) in Device DVB-S 3 i read " Channel groups" ... but RS Can not determine the channels associated devices Link to comment
Nayef Posted March 10, 2013 Author Share Posted March 10, 2013 this Suggestion way support also (one channel multiple times in the channel list) i can do that with DVBViewer Pro + "Grope channels" but RS Con't Link to comment
Tjod Posted March 10, 2013 Share Posted March 10, 2013 If the channels on different Sat positions. Do they have different network ID (channel list editor in DVBViewer Pro)? Or is the ID 0? Link to comment
Nayef Posted March 10, 2013 Author Share Posted March 10, 2013 If the channels on different Sat positions. Do they have different network ID (channel list editor in DVBViewer Pro)? Or is the ID 0? Same Service ID & Same Stream ID in channel list editor in DVBViewer Pro but different Grope A + B + C ... here image for RS : one channel + different Grope but all recorder in Device DVB-S 1 i want channel Tunis + device DVB-3 ... Link to comment
Tjod Posted March 10, 2013 Share Posted March 10, 2013 My question was about the network ID. It should be different on different sat positions. The channel groups are there to tell the DVBViewer which card is able to restive which channel. And not to tell the DVBViewer to record a channel with a special card. Link to comment
Jordi Joan Posted March 12, 2013 Share Posted March 12, 2013 I'm with you. Could you think if tyour suggestion is related to mine? http://www.DVBViewer.tv/forum/topic/50740-selecting-channel-in-recording-timer/ Link to comment
Nayef Posted March 15, 2013 Author Share Posted March 15, 2013 (edited) My quwwestion was about the network ID. It should be different on different sat positions. The channel groups are there to tell the DVBViewer which card is able to restive which channel. And not to tell the DVBViewer to record a channel with a special card. ok rename channel sloved (xxxxx1) for DVB-S1 and (xxxxx2) for DVB-S2 ... and no Conflict but i have more then 3000 channel ... any way or any dev for rename all grope channel B to xxxxx2 and grope channel A to xxxxx1 i need advanced list channel list To distinguish between groups channel as color red channel for DVBS-1 and other color green for DVBS-2 or rename channel or number channel or ...?? Edited March 15, 2013 by Nayef Link to comment
