colera Posted April 1, 2013 Posted April 1, 2013 Hi, Do you have that uses this card? The CI module doesn't work. This programs working well, tbsviewer dvbdream progdvb support.zip Quote
Tony Posted April 2, 2013 Posted April 2, 2013 While I use a cable dual tuner / dual CI TBS6680, but maybe they will help my knowledge.DVBViewer as of version 4.9.9.2, and version 5.0 contains a library tbsCIapi.dll v.1.0.0.8 (I don't understand why).Try to use tbsCIapi.dll from the latest versions of other programs (v.1.0.1.0 or later) from tbsdtv.com. Quote
colera Posted April 2, 2013 Author Posted April 2, 2013 Thanks for answer, I tried (1.0.1.0 and 1.0.1.1) nothing's changed Quote
colera Posted April 3, 2013 Author Posted April 3, 2013 Steve (from tbsdtv) said; Hi We just have send our latest CI DLL to DVBViewer,and he said that he will update it later. waiting new version Quote
Tjod Posted April 3, 2013 Posted April 3, 2013 start menu > programs > DVBViewer > DVBViewer Pro Downloader >> and reinstall Support for Turbosight cards That will give you version 1.0.1.1 of the tbsCIapi.dll Quote
Tony Posted April 3, 2013 Posted April 3, 2013 Sorry Tjod, still gives version 1.0.0.8 (28.11.2012) Quote
colera Posted April 4, 2013 Author Posted April 4, 2013 Finally, solved. Thanks After, I changed new tbsCIapi (1.0.1.2). There is no problem for now. Quote
Tony Posted April 4, 2013 Posted April 4, 2013 Colera, where did you get this version of the tbsCIapi.dll, please? This version I still haven't tried. Quote
Tjod Posted April 4, 2013 Posted April 4, 2013 Just checked again the DVBViewer Pro Downloader gets version 1.0.1.1 from the server. Quote
Griga Posted April 5, 2013 Posted April 5, 2013 Sorry Tjod, still gives version 1.0.0.8 Maybe from the browser cache? Clear it, then download again. Quote
Tony Posted April 5, 2013 Posted April 5, 2013 Hi, new version of DVBViewer (5.0) did not bring any improvement for TBS6680 card (dual tuner/dual CI). With the bundled dynamic library (tbsCIapi.dll v.1.0.0.8) does not work. .... Maybe from the browser cache? Clear it, then download again. No, no Griga. I checked it again today. In fact, it's not important. TBS team still did not fix the driver problém of the TBS6680... Quote
ritschibie Posted May 29, 2014 Posted May 29, 2014 Hi, This is just to confirm that (at least my installation of the DVBViewer Pro 5.3 ) brought no connection to the CI of a TBS 6991SE. A (in my case) functioning workaround is copying the TBSCapi.dll from the TBSViewer (which you get with the tv card) to the DVBViewer main directory. The driver version I got was 1.0.1.3. Quote
