Lars_MQ Posted April 15, 2013 Posted April 15, 2013 We have released the new DVBViewer Pro 5.1 today. ATTENTION: You can download the DVBViewer Pro 5.1 only from https://www.DVBViewer.tv/members/We introduced a new protection system with Version 4.5, if you haven't already got the new user credentials please read also: http://www.DVBViewer...ew-credentials/Mit der Version 4.5 wurde ein neues Benutzerdatensystem eingeführt, wer die neuen Daten noch nicht hat bitte unbedingt hier lesen: http://www.DVBViewer...-benutzerdaten/ Changelog DVBViewer Pro 5.1 General Fix: Playback: Playback of m2ts files with the DVBSource Filter didn't work. Fix: Main Window: Zoom 75% fixed. Fix: OSD: The screen saver was not disabled for slide shows. Fix: Timeshift: Fixed problems with timeshift for some channels. Fix: OSD: Image files with an UNC path were not shown. Fix: Tweaker.ini: The OSD Enable Tweak was missing. Change: Main Menu: Removed the Help entry. Change: Main Menu: Renamed the "Wiki" entry to “Online Help”. Change: Main Window: Auto Best Width defaults to enabled now. Fix: Recoding Window: The timer status changes were not shown correctly. Change: RTSP Device: 127.0.0.1 was not included in the SSDP search for SAT>IP servers. Fix: Options Window: Fixed problems with missing labels on reopening this window. Change: Options/Input: Changed the behavior of the “Learn” button. Add: Recording Options: Added an option to record the Current Now/Next EIT EPG data stream. Fix: Unicast Device Setup Window: The buffer count could not be adjusted. Add: ActionIDs: Added ActionID 135 for Close Graph. Fix: VCR: If a changed PMT PID was detected while recording the recording was restarted in an endless loop. Fix: VCR: TS audio only recordings with more than one audio stream sometimes an audio stream was wrongly detected as PCR stream. Fix: PMT-Parser: If the Service ID was set to 0 it was wrongly detected as PID 16. Fix: PMT-Parser: The PMT parser used a wrong PID for non ATSC audio streams with the ID $81. Update: DVBSource filter 3.7. Channel Logos It is now possible to assign a logo to a channel with the help of the "channellogos.ini" file. The DVBViewer first checks if an entry for a channel is found in this file. If it isn't found it tries the old method (guessing). The format of the channellogos.ini file is quite simple: EPGChannelID] c=[Channelname} (UTF-8 encoded) logo=[LogoFilename] The “c=” entry exists for an improved readability the program just ignores it. If a logo can't be found or doesn't exist it is marked with logo=- This avoids repeating and failing the search over and over again. Recording Service Fix: Service Options: The test button showed the XML answer of the request. Fix: Service Options: “Ignore local recording list” is now ignored if the RS support is deactivated. Change: Service Support: The MAC of the Recording Service PC (needed for WOL) is now updated on every DVBViewer start. Fix: Service Setup Wizard: Fixed problem with empty password. Fix: Service Options: Fixed problem with empty password. Fix: Fixed unnecessary memory consumption for downloading data from the RS. Hardware Change: BDA Hardware Detection: The DVB-S2 flag is now set for unknown DVB-S Devices. Fix: Hardware Options: The display wasn't updated correctly if no hardware entries were present. Add: HardwareDB: Support for Technotrend TT-budget CT2-4500 CI and Technotrend TT-connect CT2-4650 CI. Fix: Hardware/Sundtek/HDHomerun: Added a signal strength query directly after tuning. Add: HardwareDB: Support for DVBSky S680, DVBSky S960 and DigitalDevices Cine S2 V6.5. Subtitles Add: MPEG/Subtitles: Support for subtitles in MPEG files added. Fix: The “show subtitles automatically” option didn't work under certain circumstances. Fix: DVB Subtitle: Switching between different languages didn't work. Change: OSD Subtitle: The OSD subtitle display is now cleared on channel / subtitle stream changes. Change: Options/TTX Subtitle: Changed the default font size to 24 point. EPG Change: EPG Parser: The EPG Parser doesn't delete CRLF in the description text anymore. Change: EPG Processing: The language tag of the EIT EPG is now ignored if only one language is present. Fix: EPG-Export to HTML: Fixed problems with non ANSI channel names. Change: EPG Window: Unnecessary updates of the details display removed. Add: EPG: Tweak to force EPG without character set information to be recognized as ISO6937 encoded. Fix: EPG-Parser: Fixed missing last character for UTF-8 encoded EPG. Internal Task Scheduler Fix: The tasks were not created in the correct order. Fix: Fixed different defaults for the LeadTime setting. Fix: The “-i” command line parameter was not detected correctly. Fix: Running recordings are now deleted from the task list. Fix: Synchronizing the task list on DVBViewer start. Fix: Empty parameter didn't work. Fix: Timer with the same start time result now in only one entry in the task list. Streaming Playback Add: Ability to use the LAV Source Filter. By adding a "lav_" before an URL the Lav Splitter will be used instead of the own Vod Filter. VOD Source Filter Fix: Streaming Thread reading problem. Several Splitters tried to read "behind" a file which caused an endless loop inside the reading thread Fix: Exception inside GetMediaType, if no PAMMediaType is provided Fix: UserAgent changed to allow playback of HbbTV content Shaders Fix: the Bilinear Hardware Filter is disabled if you use a resample filter. To do so you have to set the ManualResample variable inside the shader script Add: Lanczos 3 and 12, Bicubic, resample shader Add: Several new Shader effects, like Old TV. Add: Stereo 3D Left/Right to Up/Down converter, which is required for several 3D glasses like Zeiss Cinemizer OLED. Change: Shaders have been renamed and sorted into Stereo, Effect and Resample categories. 11
