zkab Posted April 17, 2013 Share Posted April 17, 2013 When upgrading DVBViewer to 5.1 I also downloaded a new set of logos from Lyngsat and extracted the *.png logos to ... CMUV/DVBViewer/Images/Logos But they do not show up with OSD (when pressing return while watching a channel) ... the old logos are still there. How do get DVBViewer to read the new logo images from CMUV/DVBViewer/Images/Logos ? Reboot & restart of DVBViewer did not help. Quote Link to comment
Tjod Posted April 17, 2013 Share Posted April 17, 2013 Put the logos in C:\Program Files (x86)\DVBViewer\Images\Logos (not the configuration folder) Quote Link to comment
zkab Posted April 17, 2013 Author Share Posted April 17, 2013 Thanks - I followed your recommendation ... it worked partly but some logos with images are not displayed with OSD. How are the connection done between an image and a OSD logo ? Is it a naming issue ? Do I have to recreate the channel/favorite list ? I don't understand why some logos work OK and some don't ... I can't see any difference between them. Appreciate any help ... Quote Link to comment
Tjod Posted April 17, 2013 Share Posted April 17, 2013 logo name should be = channel name. Replace signs in the channel name which are not aloud in file names with a space. Channel name parts in () are ignored. http://www.DVBViewer.tv/forum/topic/21378-logopacks/ or use the channellogos.ini http://www.DVBViewer.tv/forum/topic/52309-DVBViewer-pro-51/ If you use the Recording Service, there is a editor for that in the options. But you have to copy the channellogos.ini after editing from CMUV\DVBViewer\config\ in CMUV\DVBViewer\ Quote Link to comment
zkab Posted April 18, 2013 Author Share Posted April 18, 2013 Thanks for your support. I used 'channellogos.ini' and now the logos work OK ... but in the Favorite list some logos are stilll not displayed with their images but with a generic image ... How can that be fixed ? Quote Link to comment
Tjod Posted April 18, 2013 Share Posted April 18, 2013 Try updating the favorite (the EPGChannelID from the favourites are a little bit different) > delete them without logo and than add it. Quote Link to comment
