cobson Posted April 23, 2013 Posted April 23, 2013 Trying to upgrade version 5 to 5.1 on a Windows 7 64bit machine. The install fails silently, with the following application error in the Windows log: Log Name: ApplicationSource: Application ErrorDate: 23/04/2013 20:36:47Event ID: 1000Task Category: (100)Level: ErrorKeywords: ClassicUser: N/AComputer: MrPuterDescription:Faulting application name: DVBViewer_setup.tmp, version: 51.52.0.0, time stamp: 0x2a425e19Faulting module name: DVBViewer_setup.tmp, version: 51.52.0.0, time stamp: 0x2a425e19Exception code: 0xc0000005Fault offset: 0x00007911Faulting process id: 0xc18Faulting application start time: 0x01ce4059e4080d7dFaulting application path: C:\Users\Chris\AppData\Local\Temp\is-DMU4F.tmp\DVBViewer_setup.tmpFaulting module path: C:\Users\Chris\AppData\Local\Temp\is-DMU4F.tmp\DVBViewer_setup.tmpReport Id: 22a764b9-ac4d-11e2-9a76-206a8ad71701Event Xml:<Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Application Error" /> <EventID Qualifiers="0">1000</EventID> <Level>2</Level> <Task>100</Task> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2013-04-23T19:36:47.000000000Z" /> <EventRecordID>2110</EventRecordID> <Channel>Application</Channel> <Computer>MrPuter</Computer> <Security /> </System> <EventData> <Data>DVBViewer_setup.tmp</Data> <Data>51.52.0.0</Data> <Data>2a425e19</Data> <Data>DVBViewer_setup.tmp</Data> <Data>51.52.0.0</Data> <Data>2a425e19</Data> <Data>c0000005</Data> <Data>00007911</Data> <Data>c18</Data> <Data>01ce4059e4080d7d</Data> <Data>C:\Users\Chris\AppData\Local\Temp\is-DMU4F.tmp\DVBViewer_setup.tmp</Data> <Data>C:\Users\Chris\AppData\Local\Temp\is-DMU4F.tmp\DVBViewer_setup.tmp</Data> <Data>22a764b9-ac4d-11e2-9a76-206a8ad71701</Data> </EventData></Event> support.zip Quote
cobson Posted April 23, 2013 Author Posted April 23, 2013 Fixed. I was trying to install from a network drive. Doing it from the local drive worked ok. Quote
