dmitrydn Posted May 1, 2013 Posted May 1, 2013 Hello, I'm trying to establish streaming to my Galaxy S3/iPAD devices from RS w/o any success. While I have watched TV from any computer in my local Ethernet but right now I need more mobility and flexibility. Thus I have been started to play with streaming features of RS. Thus the situation is as following I can watch TV from DVBViewer Pro installed on my desktop/laptop but I cannot do the same from other device. Can anybody point me to some guide with clear description on how to set-up such streaming option? While I think that I cannot open stream for any TV channel as RS is streaming the the channel without unscrambling it before. I will try to add some FTA channel to double check it but any way I need a clear answer on the question in the subject. Thanks for any help in advance, Dmitry.
Tjod Posted May 1, 2013 Posted May 1, 2013 Does RS unscramble the stream before pass it to net ? Not really, the RS tells the TV driver which streams it wants. And the TV driver handles the rest (CI, CAM and smart card are responsible for the decryption). And the RS gets the unscrambled streams from the TV driver. And as a result only unscrambled streams are passed to the net.
gqsun Posted May 1, 2013 Posted May 1, 2013 If you use plugin to descramble You cam put the plugin in plugins/plugins1 and it will be loaded by RS
dmitrydn Posted May 1, 2013 Author Posted May 1, 2013 Yes, I'm using the plugin to descramble the stream and it located just in Plugins folder. So RS is loading it from other subfolder within Plugins in the different way than DVBViewer, really? Thank you for reply, I will try however never heard it before. If you use plugin to descramble You cam put the plugin in plugins/plugins1 and it will be loaded by RS
Griga Posted May 1, 2013 Posted May 1, 2013 Yes, I'm using the plugin to descramble Forum rules: § 13 Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes. Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM)and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not. Topic closed.
