bccrew Posted May 23, 2013 Posted May 23, 2013 Hello, Too bad driver development for the FloppyDTV has stopped for a while and since version 5.0 of DVBViewer I experience a weird phenomenon.5/10 times after booting my mediacenter (Windows 7 64bit), DVBViewer complains with the message "No hardware available". I see the device listed in the device manager of Windows 7 and when I check in DVBViewer the FloppyDTV card is recognized. I tried unchecking "use internal filter..." but that didn't help.When I reboot the computer I have 9/10 chance that DVBViewer recognizes the FloppyDTV. I never had any problems with 4.9.6.20 but since 5.0 I regularly have this error 3-4 times per week. It happened only twice that I had to reboot my computer 2x before the dvb-s card was recognized. === FireDTV BDA DVB-S2 ===Description = FireDTV BDA DVB-S2DeviceID = AVC\DIGITAL_EVERYWHERE&FIREDTV_S2__&TYP_5&ID_0\4A2B000424871200DriverVersion = 5.0.6201.3000DriverDate = 30/07/2009Manufacturer = Digital Everywhere Motherboard: Gigabyte GA-73PVM-S2H CPU: Intel Core Duo E6600 Chipset: NVIDIA Geforce 7100 Windows 7 64 BIT patched fully. Quote
Griga Posted May 24, 2013 Posted May 24, 2013 http://www.DVBViewer.tv/forum/index.php?showtopic=2210 Maybe Windows Mediacenter background services temporarily occupy your FireDTV for collecting EPG data etc. Microsoft is quite possessive in this respect. Quote
bccrew Posted May 24, 2013 Author Posted May 24, 2013 Hmm I attached the support.zip but it seems to have failed.. How can I re-attach it? https://dl.dropboxusercontent.com/u/48828456/support.zip Quote
majstang Posted May 24, 2013 Posted May 24, 2013 (edited) I had similar problems with DVBViewer 5.0 too when resuming from hibernation, but with Blackgold tuners. The issue went away when upgrading to DVBViewer 5.1. What kind of AV software do you have? Edited May 24, 2013 by majstang Quote
Tjod Posted May 24, 2013 Posted May 24, 2013 The RS is installed but the DVBViewer is not configured to work with the RS. Uninstall the RS or configure the DVBViewer correctly. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer That should fix you problem. Quote
Griga Posted May 24, 2013 Posted May 24, 2013 You have installed the Recording Service with DVBViewer. In this case both must be configured correctly. Particularly DVBViewer must be configured as Recording Service client without direct hardware access: http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide Quote
bccrew Posted May 24, 2013 Author Posted May 24, 2013 Allright guys, thanks. I will try these things tonight. Muchos gracias! Quote
