Two bugs (RS 1.26.0.0)
1. First bug:
Let us have in EPG the following programs on channel with name "Smichov":
- program No. 1 with name "Meda Beda" from 18:25 to 18:40
- program No. 2 with name "Flintstone" from 18:40 to 19:10
Let us have defined the following recording events:
- recording event No. 1 with name "Flintstone" with searched string "Flintstone", begin time offset 15 minutes, end time offset 15 minutes.
- recording event No. 2 with name "Meda Beda" with searched string "Meda Beda", begin time offset 15 minutes, end time offset 15 minutes.
Then Autotimer create wrongly only one timer for "Flintstone" from 18:25 to 19:25.
But I need timer for "Meda Beda" from 18:10 to 18:55 too because this program never start exactly at 18:25.
2. Second bug:
When I disable this created timer for "Flintstone" from 18:25 to 19:25 and run Autotimer again - timer for "Meda Beda" still not created! In "Search EPG" window this concrete program "Flintstone" is showed wrongly with yellow backgroud.
I must timer for "Flintstone" completely delete - then Autotimer create timer for "Meda Beda".
Disable Check against: "Rec. Title", "Rec. Event" and "Timer Name" in the search preset
Sorry for answer delay, but these check boxes are all disabled.
Edited by jirim100
Most likely the search phrase or some setting for this autosearch is wrong.
The second timer ist created correctly.
Lars, in Support.zip are timers of course modified to prove both programs record (I can't wait after you release hot fix or new version but I must find workaround).
More specifically: I decreased manually begin time offset for added programs "Flintstone" from 15 minutes to 12 minutes and then run Autosearch again - after it Autosearch finally added second programs "Meda Beda".
That does not change the problem that I mention in this topic.
Edited by jirim100
It's known the autosearch timer behaves a bit buggy when it comes to unusual pre- and postroll time settings. If setting both to 0 min you get duplicate timers and now you're showing if setting them too long, some timers won't be created at all. Good luck with getting any more attention from dev regarding this problem. Guessing this function is probably set in stone and won't be messed around with other than fixing serious bugs, which this one isn't. Just use sensible pre- and postroll timings and everything will work.
  • 1 year later...
1. First bug:
Problem solved in version 1.30.0. Thank you!
