Ludus Posted June 16, 2013 Posted June 16, 2013 (edited) Hi guys i am new Please i have some problem to import the list transponder .ini with DVBViewer 5.1.0.0 ProHow can i import the files with list freq. of the transponder sat with extension .ini ?I download it from web site Satelliweb.com, then i'll put to inside the folder transonder, but the freq. information of every single sat that are inside the file .ini not appear in the trasponder list (look the pic below) in Seraching Channel window, so i can't get the freq. of the channe feeds becouse its not refersh the list drop downI hope that you can understabd my problem I hope its not a bug. Edited June 16, 2013 by Ludus Quote
Tjod Posted June 16, 2013 Posted June 16, 2013 The transponder folder inside the DVBViewer folder is there basically to trick users. Put the .ini in the transponders folder in the configuration folder Quote
Ludus Posted June 16, 2013 Author Posted June 16, 2013 (edited) Inside DVBViewer folder under Program Files folder?Exemple:C:\Program Files\ -> DVBViewerI did it but the transponder list default make me confiusion, what can i delete it?In this way a can see only the satellite of my files .ini Edited June 16, 2013 by Ludus Quote
Griga Posted June 16, 2013 Posted June 16, 2013 No. As Tjod already posted, store it in the Transponders subdirectory of the configuration folder. Please follow the link by clicking on it (in case you don't know how to use links yet ) Quote
Ludus Posted June 16, 2013 Author Posted June 16, 2013 Griga maybe i summed up what you and Tjod sayC:\ProgramData\CMUV\DVBViewer in program data?Give me conferm becouse i have the italian version, but i think so becouse now i see my file .ini (Eutelsat 10° E) in dropdown list Quote
Ludus Posted June 16, 2013 Author Posted June 16, 2013 Ok guys thanks for your help, i fix it now is okDVBViewer is able to show the channels in 4:2:2 in default or i must install some codecs?Now i receive the EBU channel service in 16:9 but i dont remeber if in this days i installed something Quote
Derrick Posted June 19, 2013 Posted June 19, 2013 DVBViewer is able to show the channels in 4:2:2 in default or i must install some codecs? Without decoders you won't see or hear anything Install the LAV filters. They can cope with mpeg2 and H.264 in 4.2.0 as well in 4.2.2 1 Quote
Ludus Posted June 20, 2013 Author Posted June 20, 2013 I installed it LAV, infact i see the feeds EUROVISION on 7° EI thinking about that only the shareware codecs can show the 4:2:2 Thanks Quote
