dorjee Posted June 23, 2013 Posted June 23, 2013 With DVBViewer Pro, Quad tuner and Windows XP. I wonder how I can open a PIP window. I didn't find the trick anywhere. Quote
Cian Posted June 24, 2013 Posted June 24, 2013 I know if I double click on the small picture it swaps places with the large picture, but how do I swap the audio only? I know I read it somewhere before, but can't find it now. C. Quote
Tjod Posted June 24, 2013 Posted June 24, 2013 OSD-red OSD-blue > help (while pip is active) for more informations Quote
dvbrewer Posted June 24, 2013 Posted June 24, 2013 I know if I double click on the small picture it swaps places with the large picture, but how do I swap the audio only? I know I read it somewhere before, but can't find it now. C. Any reason why you can have movie/video in background but cannot swap it to the PiP window? Quote
dorjee Posted June 24, 2013 Author Posted June 24, 2013 What's OSD menu? I use the top menu: DVBViewer/Channel/View/Settings/Plugins nothing about pip in these options... Quote
dorjee Posted June 25, 2013 Author Posted June 25, 2013 Ah, yo! I didn't miss a great thing: a shit menu scrolling from its own will and pip doesn't work. Thank you despite. Quote
Gioxy Posted June 26, 2013 Posted June 26, 2013 To make PiP work you have to fine tune DVBViewer DirectX settings for main screen and PiP window, so please read Wiki's Options Picture in Picture page, mainly the last phrase that say: Some Video decoders do not work correctly with PiP. So you might have to experiment with them a little bit. I can only add that you have to use at least VMR7 as main renderer and most probably you have to use a different Video Codec from the one used for main screen. Quote
