KennethDK Posted June 25, 2013 Posted June 25, 2013 (edited) hello. i have some problems with my keyfile when i try to install DVBViewer 5.1, it's worked on my old Windows 7 64 bit version, but have some problems, so i re-installed from scrats Windows 7 64 bit, but now when i ise keymanager7keytool it's says my keyfile is invalid, it's anybody know what i could do, i have alao tried to download the key file from my mail and the keyfile have the right file extension, så i not now what's wrong. Edited June 25, 2013 by KennethDK Quote
KennethDK Posted June 25, 2013 Author Posted June 25, 2013 file size is 4kb, i think is to big. Quote
Tjod Posted June 25, 2013 Posted June 25, 2013 Yes it should be 1 KB (1024 Bytes). (size, not "file size on disk" this value can be bigger) Quote
KennethDK Posted June 25, 2013 Author Posted June 25, 2013 Yes. but is 4 Kb., but what can i do to get it to work. Quote
Griga Posted June 25, 2013 Posted June 25, 2013 i have alao tried to download the key file from my mail Maybe it has been converted from a binary to a text format which would explain the 4k file size. What happens if you open it with a text editor? Try to download in a different way to get the binary file, e.g. by right-clicking the link and selecting "save target as" (or similar). Quote
KennethDK Posted June 25, 2013 Author Posted June 25, 2013 i have tried to download it is other ways, the file size is about 4 kb also in my mail, and i have tried to open in a text editor, is not readably, the contents looks encrypted, is it possible to send the keyfile to somewhere to DVBViewer can look at it Quote
