aydin1954 Posted June 28, 2013 Posted June 28, 2013 I am probably missing something but.... is there a way to configure to turn off on screen message "icons" after a given time they are displayed? I mean the ones like "recording" or "audio/mute" see below. Thanks. Quote
Tjod Posted June 28, 2013 Posted June 28, 2013 For recordings yes http://en.DVBViewer.tv/wiki/Options_Recorder "Signal Ongoing Recordings in the Video Window" for mute no (you should see the reason for hearing nothing) Quote
aydin1954 Posted June 28, 2013 Author Posted June 28, 2013 THANKS!! Yes it was mainly the recording I wanted to get rid of. The other is not so important and yes it is best to know why there is no sound coming out.... Also in the Wiki are missing two new options on filler data. If it could be updated..... thx. Quote
hackbart Posted June 28, 2013 Posted June 28, 2013 If you do not want them, you can remove the images and/or change the settings inside the videoinfo.xml Quote
Tjod Posted June 28, 2013 Posted June 28, 2013 Also in the Wiki are missing two new options on filler data. If it could be updated..... thx. Feel free to add them in the Wiki If you don't know then but lice to add them to the Wiki feel free to ask. (Answering a question take for me a lot less time then writing good English in the Wiki) Quote
aydin1954 Posted June 28, 2013 Author Posted June 28, 2013 Feel free to add them in the Wiki If you don't know then but lice to add them to the Wiki feel free to ask. (Answering a question take for me a lot less time then writing good English in the Wiki) I happily would but .... yeah no idea what they are LOL about the English I sure can help as mine is not bad at all so if you want to put it in your way I can help to polish it off.... But will see if I can add the remove icon one as that one is also missing and that I know what it does. Quote
aydin1954 Posted June 28, 2013 Author Posted June 28, 2013 If you do not want them, you can remove the images and/or change the settings inside the videoinfo.xml Than you very much. But I am happy with the settings for now. Quote
aydin1954 Posted June 28, 2013 Author Posted June 28, 2013 ok I added the icon option description in the wiki.... maybe double check it just in case... thanks. For the other two options a new screen cap is needed.... Quote
aydin1954 Posted June 28, 2013 Author Posted June 28, 2013 ok I see the filler options in the German version of the Wiki, I will translate them to English as I know fairly good German. If i have questions... will ask. Quote
