aydin1954 Posted July 4, 2013 Share Posted July 4, 2013 When I want to set a timer in Recording Service, I cannot see some channels that are present in DVBViewer. My understanding is that Recording Services takes the channel list from DVBViewer so this is a bit surprising and the question is how can I fix this? Thanks. Link to comment
Tjod Posted July 4, 2013 Share Posted July 4, 2013 Use the channel list editor in DVBViewer for the comparison. And restart the RS (to make sure that the RS has the current list). Link to comment
aydin1954 Posted July 4, 2013 Author Share Posted July 4, 2013 Maybe I did not explain myself properly.... so some images here is how it is in DVBViewer: Notice two instances of the channel in question one in stereo one in AC3 Surround. Now here in RS: only one instance of the channel the AC3 Surround one.... the stereo one is missing. Actually this is on one machine on another is the exact opposite and actually is that one I want to fix as I do not want to record the stereo one but the AC3 one. Link to comment
Tjod Posted July 4, 2013 Share Posted July 4, 2013 Only the main audio track is in the RS list. You can change the main audio track in the channel list editor via drag & drop. For recordings I would recommend recording all audio track http://en.DVBViewer.tv/wiki/Options_Service_-_Recorder#Format_options Link to comment
aydin1954 Posted July 4, 2013 Author Share Posted July 4, 2013 (edited) thanks I did try it, did exit RS then did drag and drop to change it and clicked apply. Did turn off and back on DVBViewer to verify that the change stayed: Restarted DS but unfortunately it did not pick up the change... any idea? Edited July 4, 2013 by aydin1954 Link to comment
aydin1954 Posted July 5, 2013 Author Share Posted July 5, 2013 .... and the answer is : reboot your computer! LOL the usual IT mantra : did you turn it off and back on? But I wish there was another way to force a refresh in RS. Link to comment
Tjod Posted July 5, 2013 Share Posted July 5, 2013 Stop the RS (make sure the tray tool is gray ) and start the RS. Link to comment
aydin1954 Posted July 5, 2013 Author Share Posted July 5, 2013 that I did not try but I did try to fully exit it and then restart it and that did not work. And isn't that more radical? Link to comment
Tjod Posted July 5, 2013 Share Posted July 5, 2013 No. You have to stop the Recoding Service process (DVBVservice.exe) not the try-utility (DVBVCtrl.exe). The try-utility is a way for user interaction with the Service process. And not really necessary. You can stop the try-utility, but still use the RS e.g. use the web interface or run recordings or use a DVBViewer client. http://de.DVBViewer.tv/wiki/Service_Control (Germen) Link to comment
aydin1954 Posted July 5, 2013 Author Share Posted July 5, 2013 thanks for the clarification now I got it. Link to comment
