Zidan Posted July 8, 2013 Posted July 8, 2013 Hi, Does anyone know why my DVBViewer 5.1.0 version can't not tune some frequencies of cable operator(in nordic countries). Issue frequencies 290MHz,298MHz,306MHz, ...other usual frequencies was tuned correctly. Settings: Transponder List>none Symbolrates: 6900,6111,6875 In-depth Search, Update does not help me Device USB 2.0 BDA DVB-C Tuner TT-connect CT-3650 CI - TechnoTrend PC Dell D620 Windows XP pro Reception Type> Cable Group>A Thank you&best regards, Zidan Quote
Tjod Posted July 8, 2013 Posted July 8, 2013 Try a transponder list which matches at least for some channels and select "In-depth Search" Or use TransEdit Transponder List=none (DVB-C) >> internal fix transponder list with 111 frequency. Quote
Zidan Posted July 8, 2013 Author Posted July 8, 2013 This could be a problem, Transponder List=none (DVB-C) >> internal fix transponder list with 111 frequency, fhis fix list may be not include my missing frequencies (290MHz,298MHz,306MHz)... I will try to Edit list Quote
Tjod Posted July 8, 2013 Posted July 8, 2013 If you us TransEdit try "Update" instead of editing it manually. http://www.DVBViewer.com/griga/TransEdit%20E/MainWindow.html#Scan ("In-depth Search" gives the same result but only temporary for one scan) Quote
hurda7 Posted September 27, 2016 Posted September 27, 2016 (edited) Using the "Scan Frequency"-button of DVBViewer's "Channel Scan", I cannot scan for DVB-C-channels on 298MHz. It's either 306MHz or 296.5MHz, and DVBViewer automatically sets the Frequency to 296500 kHz. Transponderlist is set to "none". Is 298MHz not a valid DVB-C-frequency? Edited September 27, 2016 by hurda7 Quote
Griga Posted September 27, 2016 Posted September 27, 2016 Which transponder list do you use? You can edit transponder lists (add / delete / modify frequencies) by downloading and using the TransEdit tool. Please read the included ReadMe. More information is available here and here. Quote
Derrick Posted September 27, 2016 Posted September 27, 2016 ..and please don't jump on an old outdated thread. There have been many changes since Quote
hurda7 Posted September 27, 2016 Posted September 27, 2016 (edited) Which transponder list do you use? "none". I just wanted to scan frequency 298MHz with 6900 kSym, however DVBViewer won't let me. Pretty much all digital whole-MHz frequencies (i.e. not like 114.5MHz) between D113 and D306 can't be selected without a pre-defined transponderlist. DVBViewer has a good and working channel-scanning-feature, why use another tool to do the same? ..and please don't jump on an old outdated thread. There have been many changes since The problem is happening in the latest version 5.6.4, so there's no point in opening another thread for the same unresolved issue. Edited September 27, 2016 by hurda7 Quote
Griga Posted September 27, 2016 Posted September 27, 2016 "none". "None" isn't supported by DVBViewer Pro 5.6.4 anymore, so you are for sure always using a transponder list. There is no other way but using one of the available transponder lists or creating your own by using TransEdit. The "Cable All" list that is supposed to replace the former scanning without transponder list contains 298MHz with 6900 kSym. Quote
