hackbart Posted July 15, 2013 Posted July 15, 2013 We have released the new DVBViewer Pro 5.2 today. ATTENTION: You can download the DVBViewer Pro 5.2 only from https://www.DVBViewer.tv/members/We introduced a new protection system with Version 4.5, if you haven't already got the new user credentials please read also: http://www.DVBViewer...ew-credentials/Mit der Version 4.5 wurde ein neues Benutzerdatensystem eingeführt, wer die neuen Daten noch nicht hat bitte unbedingt hier lesen: http://www.DVBViewer...-benutzerdaten/DVBViewer Pro 5.2 In Memoriam - Lars GehreChangelogGeneral Fix: Weather: Errors inside the XML-Weather information are ignored. Add: HbbTV: HbbTV Engine for CE-Html and HbbTV related content. Add: HbbTV: Parser for AIT transmissions provided by the broadcasters. Add: HbbTV: Passive mode available via Tweak.ini. Add: HbbTV: Ability to inject javascript for certain channels. Add: HbbTV: Ability to add own User-Agents for certain websites Add: HbbTV: Ability to switch between transparent and colorkey mode. Fix: Channel AutoUpdate: Wrong PMT tables where left uncorrected. Change: Client Tuning Priority Default: Default value is set to 50 Add: Teletext: Persian (ira) Teletext language is set to arabic by default Change: Channel Scanner: False frequencies entered by the user are automatically fixed if no transponder list is used. Add: UPnP: You can now open a Upnp Browser under the DVBViewer menu. Hardware Fix: RTSP Device: more detailed Keep-Alive timing Fix: RTSP Device: optimized command sequences Fix: RTSP Device: closing the device caused sometimes exceptions in UDP mode Fix: RTSP Device: Sat>IP Server from Digital Devices should now work fine Fix: Hardware Framework: PIDs for NULL-Packets can be added. Change: RTSP Device: The device detects if the RTSP Server is a Recording Service. If so you can additionally use the TCP Option. Change: BDA Devices: DVB-S BDA devices with unknown vendor are now marked as DVB-S2 compatible by default. EPG Fix: EPG: simplified management of EPG information More informations about the DVBViewer HbbTV Plugin 3
