Weird sound problem on just two channels
garyread
I have DVDviewer set up fine. All FTA channels work fine on Astra 2 except two radio channels - Radio 5 live and Radio 5 live extra. It sounds as if everything is double speed. I have re-scanned the channels, mchecked the settings all to no avail.
I have even tried installing ProgDVB and the channel sounds fine. I listen to this channel the most and its very frustrating, I would appreciate any ideas.
Best wishes
Gary
Edited by garyread
About which DVBViewer you ar talking?
what kind of sound sends this station? normal 48kHz with 192...
Maybe it's mono, you need another audio decoder. Try the Odio Dekoda from Elecard/Moonlight.
Bye
I have DVBViewer V2.3 Beta.
That's easy. Make sure that you are using the latest DVBViewer 2.3 update and the DVBViewer Filter (Options/ Advanced). Tick that "Automatic Audio Detection" checkbox under Options/ DirectShow Filters/ Source Filter. It lets the DVBViewer Filter 2.0 tell the audio decoder which format it has to handle (some are too stupid to find out by themselves).
decoder, not user :idiot:
As a quick supplementary (and unrelated) question, can you recommend the best software to convert Video files to Divx avi's
Many thanks again
Gary
Hmmm its not easy to answer, because there are many ways to do this and its a question of your handling.
here was few days ago a discussion about this theme.
cheers
Steffen
