hackbart Posted August 10, 2013 Posted August 10, 2013 Hi, i've assembled a small sample plugin which would help you to browse additional channels more easily by selecting them in a list. This version is just a 45minute build, so don't expect anything fancy. It is far away from beeing complete, so it would be nice to add new stations in the osd as well as categories and/or preview images. I also use the Mymusicfile Template for it, so do not wonder that My Music is written on several skins (Thats not a bug). The next step could be to create an own skin window. In the hope that somebody is interested in improving it i also attached the Delphi source to it. browser.zip Quote
nordstern70 Posted August 10, 2013 Posted August 10, 2013 Christian, where the zip should be extracted? Quote
hackbart Posted August 10, 2013 Author Posted August 10, 2013 dll and ini file have to be placed into the Plugin folder. The other files can be ignored, unless you know how to compile them. Quote
hackbart Posted August 10, 2013 Author Posted August 10, 2013 No into the DVBViewer program folder under Plugins. This one is just a simple OSD plugin, like the youtube one. Quote
Siggi0904 Posted August 11, 2013 Posted August 11, 2013 I'm getting an error in the osderror.log with this plugin. The following error: 11.08.13 13:03:26.173 TOSDWindowManager A window with the id already exists: 99997 Quote
hackbart Posted August 12, 2013 Author Posted August 12, 2013 Yes, thats probably because you have a plugin with this window id running. Quote
andi_s Posted September 16, 2013 Posted September 16, 2013 Hello, I just installed the plugin (copied .dll and .ini to plugins folder) and started DVBViewer, but I got no OSD Menu--HbbTV Browser. What is missing? I am using the actual versions of DVBViewer (5.2.8.1) and HBBTV Plugin (2.0.0.3). Thanks for your help, Andi Quote
hackbart Posted September 16, 2013 Author Posted September 16, 2013 This version is outdated, to be more specific the interface has been changed. Please use the online plugin instead. Quote
webmaher Posted September 16, 2013 Posted September 16, 2013 Online plugin is OK, but you cant watch normal web pages, because you cant add |0|0 in link just like before in hbbtv.ini file In new version we have hbbtv.xml and when I add my links manual and go to OSD-HBBTV I got always default menu without my links....Can you please somebody help me ... Quote
hackbart Posted September 17, 2013 Author Posted September 17, 2013 I will upload an update later this day. 1 Quote
rodjd Posted October 25, 2016 Posted October 25, 2016 please make update without this files hbbtv not work i tried everything I read on forum i post in http://www.DVBViewer.tv/forum/topic/58885-hbbtvmheg-5-engine/ examples images Quote
hackbart Posted October 25, 2016 Author Posted October 25, 2016 First of all stop trolling around. The PM in the forum is not intend to nag me or others in order to answer your questions. There is a search function. Before this i recommend to read the wikipedia entry about HbbTV first. Because it seem to be that you have absolute no idea what this is good for. To shorten things up: HbbTV is a service provided by tv stations in order to offer additional internet content. HbbTV is a subset of Html with additional functions. If you tune a tv station with HbbTV support, you see a red button icon which informs the user that he can start HbbTV by pressing the red button (F5 on the keyboard for example). If you want to add additional web services you can use the plugin interface for. And again use the Search function. Quote
rodjd Posted October 25, 2016 Posted October 25, 2016 If you want to add additional web services you can use the plugin interface for. how add this list http://www.DVBViewer.tv/forum/topic/52981-bedienung-hbbtv/page-2#entry392619 with this browser.zip ? you make a update for this dll and ini browser ?only with this i see hbbtv why ? Quote
