JochenEP Posted September 8, 2013 Share Posted September 8, 2013 Hi, after updating from DVBViewer 5.1.0 to 5.2.7 I received an error message "Program can not be started because avcodec-53.dll is missing on your computer". I removed the DVBViewer installation and installed new the recent version - same error message coming twice after starting the application. After confirmation of the OK check boxes the program runs, but I am not sure how stable. Any ideas? Thanks! Jochen Windows 7 Directx 11 AMD Radeon 6570 ASUS M4A87TD motherboard AMD Phenomeon II CPUs support.zip Quote Link to comment
Clemens123 Posted September 10, 2013 Share Posted September 10, 2013 Put the attached dll in the DVBViewer.exe folder (the main folder of DVBViewer) Quote Link to comment
hackbart Posted September 10, 2013 Share Posted September 10, 2013 You do not use the HbbTV engine, i suppose the messages comes from a decoder you are using. The probably best solution is to install the LAV Filters (http://1f0.de/downloads/) which run fine with almost every audio and video format. After installation you should select them under options->directx. Quote Link to comment
