boborg Posted November 9, 2004 Posted November 9, 2004 (edited) A friend has cable and some channels are digital FTA. Since I have good experiences with my Skystar 2 DVB-S I suggested to him a CableStar DVB-C card. Only one thing before he buys one. Can you scan the channels in DVBViewer without knowing the parameters for them? I ask because the cable company insists renting out a no good cheap DVB-C receiver to him and you can't even read out the frequency in there. They won't give him any information about which frequencies the digital channels are on. Edited November 9, 2004 by boborg Quote
Griga Posted November 9, 2004 Posted November 9, 2004 Can you scan the channels in DVBViewer without knowing the parameters for them? The DVBViewer provides DVB-C transponder lists for different QAM values. Probably your friend must try them all... There is a bug affecting DVB-C scanning in DVBViewer 2.2 RC1, however. AFAIK fixed in 2.3 Beta. With the DVBViewer TE it should work. More about it here. Quote
boborg Posted November 22, 2004 Author Posted November 22, 2004 (edited) After digging deeper I think some channels on the cable net are broadcasted with a Symbolrate of 7146. As the Cablestar on the specs. only goes to 7000 he would not be able to use anyway if he bought one? Edited November 22, 2004 by boborg Quote
eto Posted December 4, 2004 Posted December 4, 2004 I have a Cablestar card and I yes you can use different sysbol rates, for example where I live 6875 KS/s is used, works fine with TSReader for example. My problem is I've not figured out how to change the symbol rate when scanning for channels in the channellist/channel scan option. Symbol rate seems to always stay @ 6900 KS/s Suggestions/input is welcomed. Quote
Guest Oliver Posted December 4, 2004 Posted December 4, 2004 When clicking on "symbol rates" you should be able to enter additional values. Bye, Oliver Quote
Griga Posted December 4, 2004 Posted December 4, 2004 You can change it in the transponder list (the CableQxx.ini file in DVBViewer\Transponders) that is used for scanning. Open it with a text editor and search/replace 6900 by the desired value. Quote
eto Posted December 4, 2004 Posted December 4, 2004 (edited) You can change it in the transponder list (the CableQxx.ini file in DVBViewer\Transponders) that is used for scanning. Open it with a text editor and search/replace 6900 by the desired value. Thanks, I was about to answer my own post, hadn't tried it yet and then realised that it must be obvious. Sorry for the background noise. Edited December 4, 2004 by eto Quote
boborg Posted December 6, 2004 Author Posted December 6, 2004 I did get a chance briefly to test a Cablestar and I found that only the frequencies and symbolrates in the ini file were scanned while any other values you wrote inside DVBViewer are ignored. Guess it's a DVBViewer bug since the Cablestar isn't as tested as Skystar 2 is with DVBViewer. Quote
