FIC spectra
el_domingo
Hello,
I have set an Win7/64bit AMD A5700 Cpu with AMD A85 chipset in a FIC spectra case.
There are two major problem.
1. With PCI riser card I wanted to use both Terratec DVB-S2 and DVB-C receiver bot windows accept only DVB-C and for the other giving error code 12 no resource. As far as I understod it doesn't accept with a rise card. I have only 1 PCI slot on my mobo, how can I solve it ?
2. There is VFD and in the manuel says " LED Display Module TOSD-5711BB 120*25*12 mm (Taiwan
Oasis". As far as I understood while searching on the net Elonex Artisan - FIC Spectra Fujitsu Scaleo E VFD Front Display is same.
There is no unrecognized device in device manager but only hdd sign blinking on VFD display.
How should I get worked first then how can I use with DVBViewer.
Thanks.
If you have only one PCI Slot on your board you can use only one PCI device. You could buy an additional USB DVB-S or C receiver.
