McenterFreak Posted November 18, 2013 Share Posted November 18, 2013 Hello I have a very strange problem My RS server has Win 8 Client 1 has Win 8.1 Client 2 has Win 7 Client 1 (and another client with Win 8.1) can't tune to DVB-S2 channels that are encrypted. I get the message "No hardware available". I use SmartWii to share subscription Card to 3 tuners in the RS server. Client 2 has no problem tuning the channels I use DVBViewer on clients I have atached suport.zip for all 3 configurations support client Win 7.zip support client Win 8.1.zip support server.zip Link to comment
Moses Posted November 18, 2013 Share Posted November 18, 2013 You did not tick "DVB-S2" on the Unicast Devices on your Windows 8.1 client. So the DVBViewer does not know that the server hardware can do DVB-S2. So also unencrypted DVB-S2 channels should give the same message. Link to comment
Derrick Posted November 18, 2013 Share Posted November 18, 2013 You did not tick "DVB-S2" on the Unicast Devices on your Windows 8.1 client. There is one DVB-S2 device on the W8.1 client <section name="Unicast Network Device 3"> <entry name="HasCI">1</entry> <entry name="HasDialog">1</entry> <entry name="UseHardwareFilter">1</entry> <entry name="Name">DVB-S 2</entry> <entry name="TunerType">1</entry> <entry name="Status">1</entry> ..but the overall hardware allocation seems to be very messy Link to comment
krasno Posted November 18, 2013 Share Posted November 18, 2013 (edited) I had a similar problem recently, try to update digital devices drivers! ..if you have not done that allready of course.. http://shop.digital-devices.de/epages/62357162.sf/de_DE/?ObjectPath=/Shops/62357162/Categories/Downloads/TV_Karten_DD Edited November 18, 2013 by krasno Link to comment
McenterFreak Posted November 18, 2013 Author Share Posted November 18, 2013 (edited) Moses: You was right, thank you. I missed it, because the DVB-S2 check box has been moved. In previous versions it was together with the other check boxes, but now it is moved from left to right top corner Edited November 18, 2013 by McenterFreak Link to comment
McenterFreak Posted November 18, 2013 Author Share Posted November 18, 2013 Seems like it is impossible to use Quote in Win 8.1, IE 11, so: Derrick: You wrote that hardware allocation seem messy. Please explain Link to comment
Derrick Posted November 18, 2013 Share Posted November 18, 2013 well, maybe it's done on purpose but some devices are controlled by the RS on the server PC and some are directly controlled. Can you watch FTA on the W8.1 client? If you tune to a scrambled service does the source filter show at least the PCR? Link to comment
McenterFreak Posted November 18, 2013 Author Share Posted November 18, 2013 It was the DVB-S2 check that were missing. It Works perfect now, thanks Link to comment
