pemat Posted December 8, 2013 Share Posted December 8, 2013 Will be possible to have option to popup channel list on left or right side please? As i have extended displays and mouse goes away to other display to right side and is difficult to navigate back specially if other display is off. Thank you. 1 Quote Link to comment
krasno Posted January 18, 2014 Share Posted January 18, 2014 (edited) Will be possible to have option to popup channel list on left or right side please? As i have extended displays and mouse goes away to other display to right side and is difficult to navigate back specially if other display is off. Thank you. yes yes yes.... all pop up "things" dissapear to to the other display, which is... in another room...., hence the other display #1 is a projector...so a good sugestion !! This has been one of the problems that came when Dual Mode /Theatermode disapeared. Edited January 18, 2014 by krasno Quote Link to comment
highyield Posted September 7, 2015 Share Posted September 7, 2015 (edited) Also, it would be nice if the user could customize the width of the area which triggers the popup channel list (percent of the DVBViewer window width) and how long to display it after the mouse cursor has left the area. For me, it disappears too fast and I find it kind of hard to hit the trigger area when DVBViewer is windowed. Make them Tweaker options if you don't want them in the main GUI. Edited September 7, 2015 by highyield Quote Link to comment
Griga Posted September 8, 2015 Share Posted September 8, 2015 Will be possible to have option to popup channel list on left or right side please? Not too difficult - will be available in the next release. Also, it would be nice if the user could customize the width of the area which triggers the popup channel list ATM the width is 20 pixels in window mode and 50 pixels in full screen mode - a rather crude solution. At least it should scale with the window width, particularly with regard to 4k displays. I've changed it to 1/32 of the window width with a minimum of 20 pixels, yielding 60 pixels in full screen mode on a full HD screen. I think if the mouse cursor ist stopped at the left/right border the width of the mouse sensitive area doesn't matter so much. and how long to display it after the mouse cursor has left the area. That's a bit more demanding... maybe I will look after it if later. Quote Link to comment
