schedule recording not starting
subminiature
I am loosing many recordings and not sure what to do to correct it.
The recordings are shown in the "Timer"
They are listed in the Scheduler.
I updated the Timer and closed DVBViewer as it warns about the scheduler not being updated otherwise.
I then got no recordings until I again run DVBViewer.
It doesn't always happen. Sometimes DVBViewer opens (blank screen) and the recordings start.
blank screen? - is it tune to desired channel? if yes, and signal is strong try some other codecs...
When a scheduled recording begins it starts up DVBViewer and then I get a blank screen - no channel is selected. The recording is saved.
If I select a channel then that is displayed.
Signal not an issue. Codecs not an issue as far as I know.
The issue is that sometimes if doesn't run DVBViewer when it is scheduled to so so so I get no recording even with the recording listed in the Timer and on the Scheduler.
Thanks - I would like to but ... it gets heavy going. I'll have another look at the installation.
