why cant i record 2 encrypted channels on same transponder?
videogamingtown
why is this an issue? it says no hardware available when im switching to another channel on the same transponder, i just wanted to record 2 at the time.
  • 3 weeks later...
Obviously, you are using CAM.. Unless the tuner driver allows decrypting multichanels, this action is usualy not possible..Even with CAM mentioned DUAL. This kind of CAM can decrypt 2 chanels at the same time in compatible STB only..
I don't now by the way whether some Digital Devices multituners can do it???
Edited by trifon33
..It's not the driver but the application that doesn't allow multi_channel_decryption.
