Kiwi_Tim Posted February 21, 2014 Posted February 21, 2014 Hi, I am using DVBV 5.2.9.0 & Recording Service 1.28.0.0. on Windows 8.1 32bit. I grab my EPG using EPG Centre, and import into DVBViewer using Xepg. This is all working very well; I have a channel list that is fully populated with program times, titles and descriptions. My recordings work as expected. If I click on the 'Recordings' tab in the Recording Service browser, I see both the title and description from the EPG for each recording. However, if I bring up my 'Recordings' from within DVBV, using the Concinnity 3D skin, then click the green 'Info' button for a specific recording, I only see the recorded program's title; there is no program description. This information is clearly listed in Recording Service, but is not displaying in DVBV via the OSD. I expect that the missing program description from the OSD is entirely an OSD skin issue. I made a post over in the OSD Skin section two weeks back, but have had no response, so am posting here in the hope of getting some advice. What I want to know is which file(s) I need to edit, and how to edit them, to make the program descriptions display via the OSD Recordings Green Button. I can upload whatever OSD skin files here if someone can tell me which ones to select. Many thanks, Tim New Zealand Quote
Kiwi_Tim Posted February 25, 2014 Author Posted February 25, 2014 support.zip Here is the data from the supporttool. Hopefully somebody can point me in the right direction Quote
QBox User Posted February 25, 2014 Posted February 25, 2014 I did something similar for another skin a couple of years ago but can't remember the details. You need to download the OSDskinner application from the members area and use that to edit the appropriate file - might be MyMiniEPG.xml If you also download the DVBVSpy application, that will give you the name of the object you need to add. Quote
