Play from Enigma 2 OpenWebIF plugin
ozobucos@hotmail.com
I think you asking in the wrong forum. You can open file via command line in the DVBViewer
"C:\Programme\DVBViewer Pro\DVBViewer.exe" "D:\My Secret Videos\Sandman.mpg"
So most likely all changes have to be made in Enigma/OpenWebIF
Link to comment
I think it's a TS streaming. Here a m3u file generated by OpenWebIF, The last line it's the STB IP, port and dat of the channel.(La 1 TVE)
#EXTM3U
#EXTVLCOPT--http-reconnect=true
h.t.t.p.:/./192.168.1.15:8001/1:0:1:1EA:3F0:22D4:EEEE0000:0:0:0:
Here and image of the codec.
Edited by ozobucos@hotmail.com
Link to comment
What happens if you put the URL in the DVBViewer menu > Open URL...
If DirectShow error "canooot render ..." make sure LAV Filters (x86) are installed.
Oh yeahhh, copy and pasting the url it's work but...
Some SD channels only work after of a forced change from a video filter to another (e.e. from LAV to Microsoft DTV DVD , or viceversa)
Some HD channels not work and anothers yes work depending of his resolution, I think that. 1920x1088 channels work fine, but 1280x720 not work.
Excuse my bad english. Not work mean a black screen.
Link to comment
If some channels are working and some not. It sounds like a problem a decoder or splitter problem.
Check which direct Show components are used. In the DVBViewer menu during playback View > Filters (black and Gray are both used only black ones having own settings).
Link to comment
yes, sure it's a problem of spliter. Thank you for the help.
Link to comment
  • 1 year later...
Hello,
Why is the IPBoard Editor not able to insert and display Code with the 2 brackets <> like in the help
http://www.DVBViewer.tv/forum/index.php?app=core&module=help > Posting > <> This will insert a codebox.
I installed DVBViewer 5.5.2 and LAVFilters 0.67.
I set up DVBViewer > Options > DirectX > use for all > LAV Video Decoder / LAV Audio Decoder.
Then I used the following Tutorial to install some channels like "Das Erste HD" and "arte HD" from Astra 19.2°.
Tutorial: DVBViewer Client mit Zugriff auf die Dreambox als Tuner
After editing the Filedevice.dat (C:\ProgramData\CMUV\DVBViewer\) it is necessary to scan for the added frequencies.
I didn't test with tuner type DVB-IPTV because I don't know how to scan and add them to my channel list.
One disappointment is that for one frequency only one channel can exist.
This means that if I add "arte HD" also to 11494;http ... then it was not found by channel scan.
If I add it with increasing number e.g. 11495 for "arte HD" then it was found.
Another disappointment is that the Channel name is "Service <SID>", " Service 10301" and not "Das Erste HD".
File devices can be different tuner types like Cable/DVB-C, Sattelite/DVB-S.
The name of an File device can be changed in hardware.xml (C:\ProgramData\CMUV\DVBViewer\).
If you have Receivers with various tuner types like Sattelite and Cable it is needed to create an second device for another tuner type.
11494;http:// 192.168.123.131:8001/1:0:19:283D:3FB:1:C00000:0:0:0::Das Erste HD
11495;http:// 192.168.123.131:8001/1:0:19:283E:3FB:1:C00000:0:0:0::arte HD
<?xml version="1.0" encoding="UTF-8"?>
<settings>
<section name="DVB File Device 2">
<entry name="HasDialog">1</entry>
<entry name="UseHardwareFilter">1</entry>
<entry name="IsFilesource">1</entry>
<entry name="Name">Enigma2 DVB-S2</entry>
<entry name="TunerType">1</entry>
<entry name="Status">1</entry>
<entry name="InstID">{266A5003-1D95-4754-832A-95F8A0EEB402}</entry>
<entry name="DeviceNr">2</entry>
<entry name="Vendor">0</entry>
<entry name="Priority">2</entry>
<entry name="Tag">0</entry>
<entry name="DeviceType">8</entry>
<entry name="Groups">255</entry>
<entry name="Retune">0</entry>
<entry name="SkipComponents">0</entry>
<entry name="DiSEqCCount">0</entry>
<entry name="Slot">0</entry>
<entry name="SlotFrequency">0</entry>
<entry name="UnicablePIN">0</entry>
</section>
</settings>
ARD.ini (Export of Provider ARD of my Channel List)
[Channel0]
TunerType=1
Root=Enigma2 DVB-S2
Category=ARD
Name=Das Erste HD (deu)
OrbitalPos=0
NetworkID=0
StreamID=1019
SID=10301
PMTPID=5100
VPID=5101
APID=5102
PCRPID=5101
AC3=16
Language=deu
Volume=0
EPGFlag=0
TelePID=5104
AudioChannel=0
Encrypted=24
Group=0
Frequency=11494
Polarity=h
Symbolrate=22000
SatModulation=0
SubStreamID=-1
FEC=-1
LNB=9750
LNB-Selection=0
DiseqC=3
DiseqCValue=0
[Channel1]
TunerType=1
Root=Enigma2 DVB-S2
Category=ARD
Name=Service 10301 (mis)
OrbitalPos=0
NetworkID=0
StreamID=1019
SID=10301
PMTPID=5100
VPID=5101
APID=5103
PCRPID=5101
AC3=16
Language=mis
Volume=0
EPGFlag=0
TelePID=5104
AudioChannel=0
Encrypted=152
Group=0
Frequency=11494
Polarity=h
Symbolrate=22000
SatModulation=0
SubStreamID=-1
FEC=-1
LNB=9750
LNB-Selection=0
DiseqC=3
DiseqCValue=0
[Channel2]
TunerType=1
Root=Enigma2 DVB-S2
Category=ARD
Name=Service 10301 (AC3,deu)
OrbitalPos=0
NetworkID=0
StreamID=1019
SID=10301
PMTPID=5100
VPID=5101
APID=5106
PCRPID=5101
AC3=17
Language=deu
Volume=0
EPGFlag=0
TelePID=5104
AudioChannel=0
Encrypted=152
Group=0
Frequency=11494
Polarity=h
Symbolrate=22000
SatModulation=0
SubStreamID=-1
FEC=-1
LNB=9750
LNB-Selection=0
DiseqC=3
DiseqCValue=0
[Channel3]
TunerType=1
Root=Enigma2 DVB-S2
Category=ARD
Name=arte HD (deu)
OrbitalPos=0
NetworkID=0
StreamID=1019
SID=10302
PMTPID=5110
VPID=5111
APID=5112
PCRPID=5111
AC3=16
Language=deu
Volume=0
EPGFlag=0
TelePID=5114
AudioChannel=0
Encrypted=24
Group=0
Frequency=11493
Polarity=h
Symbolrate=22000
SatModulation=0
SubStreamID=-1
FEC=-1
LNB=9750
LNB-Selection=0
DiseqC=3
DiseqCValue=0
[Channel4]
TunerType=1
Root=Enigma2 DVB-S2
Category=ARD
Name=Service 10302 (fra)
OrbitalPos=0
NetworkID=0
StreamID=1019
SID=10302
PMTPID=5110
VPID=5111
APID=5113
PCRPID=5111
AC3=16
Language=fra
Volume=0
EPGFlag=0
TelePID=5114
AudioChannel=0
Encrypted=152
Group=0
Frequency=11493
Polarity=h
Symbolrate=22000
SatModulation=0
SubStreamID=-1
FEC=-1
LNB=9750
LNB-Selection=0
DiseqC=3
DiseqCValue=0
[Channel5]
TunerType=1
Root=Enigma2 DVB-S2
Category=ARD
Name=Service 10302 (AC3,mul)
OrbitalPos=0
NetworkID=0
StreamID=1019
SID=10302
PMTPID=5110
VPID=5111
APID=5116
PCRPID=5111
AC3=17
Language=mul
Volume=0
EPGFlag=0
TelePID=5114
AudioChannel=0
Encrypted=152
Group=0
Frequency=11493
Polarity=h
Symbolrate=22000
SatModulation=0
SubStreamID=-1
FEC=-1
LNB=9750
LNB-Selection=0
DiseqC=3
DiseqCValue=0
[Channel6]
TunerType=1
Root=Enigma2 DVB-S2
Category=ARD
Name=Service 10302 (mis)
OrbitalPos=0
NetworkID=0
StreamID=1019
SID=10302
PMTPID=5110
VPID=5111
APID=5117
PCRPID=5111
AC3=16
Language=mis
Volume=0
EPGFlag=0
TelePID=5114
AudioChannel=0
Encrypted=152
Group=0
Frequency=11493
Polarity=h
Symbolrate=22000
SatModulation=0
SubStreamID=-1
FEC=-1
LNB=9750
LNB-Selection=0
DiseqC=3
DiseqCValue=0
So I tested and in my opinion DVBViewer is generally able to handle/play these channels (SD and HD) as http Stream including EPG and TXT functionality.
But if I try to open the URL directly then nothing happens, the windows stays black.
Please tell my how I can send you missing information e.g. log files of DVBViewer.
Edited by blueice_haller
Link to comment
  • 4 years later...
