New dvb s2 card
stefabona
Hi everybody, my skystar hd2 is dead and i need to replace it. I don't have particular needs: single tuner, low profile and no problems when resuming from standby or hibernation. My skystar was always a problem when waking up my htpc, and many times i received the message "no hardware available" so needed to reboot almost every time.
I don't need ci module ...
According to your experience, the best card for the right (and possibly low hehehe) price?
Edited by hdv
forum rules, look at §13
Hi own a skystar usb hd but I wouldn't recommend it, people seem to like tbs cards generally (pci-e ones) they have online ordering.
If you're looking for a really cheap one until you find one you like I suggest geniatech -> http://www.aliexpress.com/store/product/GENIATECH-Mygica-HDStar-DVB-S2-TV-Box/616485_699117215.html .
Look here -> http://www.linuxtv.org/wiki/index.php/DVB-S2_PCIe_Cards and read the notes on each card so you have an idea of witch-one you should buy.
Oh sorry i've forgotten.. It has to be pci not pci-e.. Any tbs pci?
I use the by hdv advised TBS8922 PCI DVB-S2 since 8 months and it works fine.
Ok, i found:
- TEVII S464 DVB-S2 Low Profile for 50,90 €
- TBS 8922 for 58,99 €
- Terratec Cinergy S2 for 109,10 €
Best choice?
  • 4 weeks later...
DVBSKy S950CI, works great for me (i've never tested the CI though)
Hi all, tbs 8922 tested for 20 days and all is perfect!
Great, stefabona!
