dvbviewer.tv Posted March 10, 2014 Posted March 10, 2014 (edited) Hi my dears users. Sory for my english For example: My desktop have icons. Suddenly i would like change my channel when press the icon on the desktop. I would like to have separately icon for my channel on desktop, for example: bbc hd.exe, zdf hd.exe,... Meybe i have to edit shortcut DVBViewer icon and add opplicable formule? Like in my music player -foobar 2000. "C:\Program Files (x86)\foobar2000\foobar2000.exe" /next <------- (arrow ) How can i do that? Edited March 10, 2014 by dvbviewer.tv Quote
GruberMa Posted March 10, 2014 Posted March 10, 2014 Hi DVBViewer.tv, http://www.DVBViewer.com/en/index.php?page=manual&chapter=f⊂=f6 describes a solution to your request. Regards, GruberMa Quote
dvbviewer.tv Posted March 10, 2014 Author Posted March 10, 2014 Hi DVBViewer.tv, http://www.DVBViewer.com/en/index.php?page=manual&chapter=f⊂=f6 describes a solution to your request. Regards, GruberMa You are a BIG MAN. Thank you. Quote
hdv Posted March 10, 2014 Posted March 10, 2014 other option is the Channel Shortcutter http://www.DVBViewer.tv/forum/topic/4313-channel-shortcutter/ if you convert the Logos into *.ico you can use for the shortcuts http://www.DVBViewer.tv/forum/topic/21378-logopacks/ Quote
Gioxy Posted March 10, 2014 Posted March 10, 2014 Hi DVBViewer.tv, for the other request (shortcut to switch channels/favorites plus or minus) you can create some special shortcuts coping the original one and adding the desired action to the DVBViewer command line like that: "C:\Programs\DVBViewer\DVBViewer.exe -x9", where: - for Channel +, the action to add is -x9 - for Channel -, the action to add is -x8 - for Favourite +, the action to add is -x20 - for Favourite -, the action to add is -x21 There are many action you can add, you can find the complete list in the file "actions.ini" located in DVBViewer main program folder... Quote
