Accessivility for blind users problim in V5.2*
hareth
Dear dev's and all,
I'm a blind user off DVBViewer pro since virsion 3.** and i'd like to say its the only viewer accessible to use via most of our screenreaders, like jaws for windows.
The new problim that happend with the new 5.2 virsion is simply it lost most of it accessibility most importantly the channel list and the options not readed by the screen reader properly any more
I'm not a tech expirt to tell what's going on with it but i've changed the skin many times with no progris
so pleas fix it or we blind users will be left with 5.1* as the last usable virsion
Great thanks in advance...
Yes sir,
I'm talking about the V 5.2.9 new one
so i had to go back with the 5..10 wich is working perfectly with csreenreaders.
thanks for replying.
  • 1 month later...
Fixed,
with the latest 4.3.0 every thing back to normal and better, on terms of accessibility for the screenreaders
Big thanks for all the dev's for fast bug fix and the kind responce, wich we don't find with other app dev's, with same problims.
again BIG thanks for keeping us up to date with the best DVB player in the world.
have a good time.
Are you sure? To be honest we did not changed anything in the code and i'm still aware that the virtualtreeview problem is still there, since we did not updated or downgraded the current virtualtreeview version. Which screen reader do you use? Is it Jaws?
Hello,
after your reply, i checked what the change i made so it was jaws i've upgrade it right before i installed the latest virsion of the DVBViewer
from jaws14 to jaws 15 and when i used the jaws 14 it was the same problimlthe channel list feedback as a single line continued as a one sentence
and we cannot select a channel as easy as the 5.10, and older versions,
also the options not accessible as above
the versions above 5.10 is not giving the proper channel list or the options list and the (tab) button wasn't working as it should in the options
wich forced me to downgrade to the 5.10,
and i've tested it with jaws-15 64 bit was working fine
but not the case with nvda screenreader and the past jaws versions
and you know that the most of the blinds using older jaws and nvda.
so pleas giv it a review to see what is going on
and what triggerd this prob
many thanks in advance..
  • 6 months later...
I'll be more than happy to test, with jaws 16 and nvda screenreaders.
you've got mail.
