No recording button.
M.T.Hansen
Hi.
After I changed my server 2008 R2 out with a Server 2012, on which my Recording Service is installed, the red recording button is missing when I press a show to record?
Does any one know why?
Link to comment
No, the time is correct on both my server and PC, and shows are not in the past. I have tried all form of browsers, and many different PCs. The problem must be in the server, something in the 2012 that is not compatible with Recording Service webserver?
Link to comment
Hi Janee. Thanks for your input. I tried the solution without any luck. I then uninstalled all DVBViewer software on my server and deleted all directories and cleaned up my registry.
After a total re-install it worked, so now my record button is back.
Thanks for your help.
Link to comment
