extended logging -webinterface
Change: Recorder Options: "Write extended log file" checkbox removed. The Recording Service now always writes an extended recording log.
The corresponding checkbox is lingering in the Webinterface/Configuration/Recorder/extended logging. It can be checked but not saved (check disappears when saving). Is this intended or should that be removed as well?
Edited by majstang
Link to comment
