dvbrewer Posted June 4, 2014 Posted June 4, 2014 As per title, changing to channels seemingly at random, support.zip attached support.zip Quote
Derrick Posted June 4, 2014 Posted June 4, 2014 ..neighbour with his remote control Please a little more input please. Quote
dvbrewer Posted June 4, 2014 Author Posted June 4, 2014 (edited) ..neighbour with his remote control Please a little more input please. No both remotes are hidden (Hauppauge & IMon)...but, the remote doesn't seem to be working either . The channels are just changing by themselves after a few minutes. Edited June 4, 2014 by dvbrewer Quote
Griga Posted June 4, 2014 Posted June 4, 2014 Some device / software sending key strokes... ? Remove the according keys on Options -> Input for a test. Quote
dvbrewer Posted June 4, 2014 Author Posted June 4, 2014 Some device / software sending key strokes... ? Remove the according keys on Options -> Input for a test. But it is illogical. I thought it might be the previous channel button being activated, but it can't be, it just continually switches to BBC One HD (0) then to BBC 2 England (2) and back. If I switch to another channel, it will switch back to 0, then 2, then 0, then 2 etc... Quote
Griga Posted June 4, 2014 Posted June 4, 2014 Channels can be selected by typing numbers. Delete Keyboard 0 and Keyboard 2 in the Input -> Channels section. Quote
dvbrewer Posted June 4, 2014 Author Posted June 4, 2014 OK now I get a runtime error & DVBViewer has stopped working properly must close message ... Quote
dvbrewer Posted June 4, 2014 Author Posted June 4, 2014 Channels can be selected by typing numbers. Delete Keyboard 0 and Keyboard 2 in the Input -> Channels section. No it still switches to 0 or 2 . Quote
Griga Posted June 4, 2014 Posted June 4, 2014 All Options -> Input -> Input Plugins are disabled? Quote
dvbrewer Posted June 4, 2014 Author Posted June 4, 2014 (edited) All Options -> Input -> Input Plugins are disabled? OK, if I disable HCWRemote plugin, the problem goes away, but now Hauppauge remote doesn't work, can I reset it somehow ? Edited June 4, 2014 by dvbrewer Quote
Griga Posted June 4, 2014 Posted June 4, 2014 The Hauppauge IR receiver is known to be very sensitive (at least true for the one that came with my Nova S2 HD), so maybe it's receiving unwanted IR signal from somewhere... cover it and see if the spooky channel change stops. If this doesn't help call a parapsychologist. Quote
dvbrewer Posted June 7, 2014 Author Posted June 7, 2014 Errr...after I vacuumed the Hauppauge S2 USB unit, the problem does not occur anymore . Quote
Griga Posted June 7, 2014 Posted June 7, 2014 after I vacuumed the Hauppauge S2 USB unit, the problem does not occur anymore I already suspected that kind of ghostbuster equipment will be necessary... Quote
